RPM's surging +/- 200 rpm's >
Old 07-21-2007 | 09:59 AM
Rocko C's Avatar
Default RPM's surging +/- 200 rpm's
I've found a lot of excellent advice on TBM in reference to this problem but I figure'd I'd throw it out here also in case someone else has experienced this maddening problem. At idle but mostly at the first throttle "click" or no-wake zone speed, the motor surges approx. 100 - 200 rpms and it's making me mental. My motor is brand new, with 27 hours on it but the intake is from my old motor so it's something to do with the intake/fuel injection setup. The advice I've received so far from LKSD, Boss232 & others is to clean my throttle body which I will do today and check the vacuum lines but, just in case it doesn't go away has anyone else experienced/fixed this ??? It really is annoying, any advice is appreciated. Oh yeah, the motor is a 2007 GM Marine Division 502 Mag MPI (415hp) base engine with the intake from my old motor. Rock
Rocko C is offline
Old 07-21-2007 | 01:03 PM
Strip Poker 388's Avatar
Rob
is it like a stumble? lean condition off idle
Strip Poker 388 is offline
Old 07-21-2007 | 02:55 PM
filed spark plugs possibly
fountainguy214 is offline
Old 07-21-2007 | 07:19 PM
believe it or not I had too much timing do that too.
lilredboat is offline
Old 07-22-2007 | 12:41 PM
Rocko C's Avatar
It does not happen at idle or when running above 1000 RPMs. It's just a constant surge, from 400 to 800, back down to 400 then back up to around 800. The only way I can get it to stop is to either back off the throttle all the way or run over 1000-1100. It's annoying because it's right at the 'slow, no wake' speed. I'm going to check the IAC motor and throttle cable adjustment as suggested by others.
Rock
Rocko C is offline
Old 07-22-2007 | 05:32 PM
If it is EFI or MPI, it is most likely your IAC,( idle air control)valve/sensor
GSS0816 is offline
Old 07-22-2007 | 05:38 PM
Try this may do it if corrosion or salt is hanging up your iac .Spray some storage seal or wd -40 in the inlet to the iac while it's running.
It's the hole above the shutter under the flame arrester. It might keep you from taking things apart.
Jim
MOBILEMERCMAN is offline
Old 08-27-2007 | 12:07 PM
Rocko C's Avatar
Default Engine Surging - FIXED !
Well, I took the throttle body off cleaned the sh*t out of it, installed a new IAC motor and TP sensor. The surging is gone and the idle is a little higher than before. The surging, at it's worst, got to about +/- 1000 RPM's...now it's just strong and steady.
One last question, though. I noticed that when I replaced the TPS that there was a little bit of room for adjustment (approx. 1/4"). What is this adjustability for and how do I know if it's adjusted properly ? Again, it's running great now, I'm just curious.
Thanks,
Rock
Rocko C is offline
Rocko C
Baja
11
09-25-2007 06:44 PM
thanks_don
Prop Talk
1
08-01-2007 12:48 PM
fountainguy214
Fountain
3
06-12-2007 07:04 PM
osen007
2
07-25-2006 11:47 AM
WETTE VETTE
1
02-08-2003 12:42 PM
