installing side exit exhaust >
Old 07-24-2007 | 12:02 AM
Question installing side exit exhaust
I was wondering if anyone could give me any tips before i go drilling any holes in my boat. I just purchased a set of hardin marine 45 degree side exit tips. Is there any special way i should go about drilling the holes and, what would i use to cap off the exsisiting exhaust. I am not using diviters so I am just using exhaust hose to connect to the tips. My motor is a 350 mag mpi, also should I expect any gains in mph?
dieselstrng is offline
Old 07-24-2007 | 01:16 AM
I doubt you will see any mph gains. My buddy has a 202 and has the side exit exhaust and does not see any mph when he switches. He also has the 7.4/310hp.
Griff is offline
Old 07-24-2007 | 01:17 AM
As far as cutting, measure 10 times before you cut. If the completely round cut outs, use a hole saw.
Griff is offline
Old 07-24-2007 | 08:46 AM
Thanks, so basically its just for noise and looks........I wont tell my wife that hahaha.
Old 07-25-2007 | 02:28 PM
the size of the exhaust is 4" so should i cut 4.25 inch holes?
Old 07-25-2007 | 02:32 PM
tblrklakemo's Avatar
SeaRay Sundancer
I would cut 4" and use a dremel or something if its too tight.
tblrklakemo is offline
Old 07-25-2007 | 02:34 PM
so would you recommed a hole saw i heard that the fiberglass eats up those saws, or a template and a dremel with a cutting bit?
Old 07-25-2007 | 02:37 PM
I appreciate the info
Old 07-25-2007 | 03:06 PM
Panic Button's Avatar
Emerald Coast of Florida
Love my side dumps in my Velocity. Due to the way the noise law was written in NV, they have to measure 1 meter from the transom, that dropped the noise to less than 85db, at the side they were over 94db.
Panic Button is offline
Old 08-28-2007 | 10:05 AM
duunoit's Avatar
I never thought of that (side exit exhaust) to combat noise regulations. What about if you ran one to each side? I would think that would help with both the stationary idle test and the running test...
duunoit is offline
