Early 502 EFI question. >
Old 07-25-2007 | 10:13 AM
Default Early 502 EFI question.
I bought an EFI set up from a guy, it is the style that uses the fuel pump on the block. My question is that on the front underside of the plenum(over top the thermostat) there is an open hole(threaded), is there supposed to be something there, or do I just put a plug in it.
Thanks Steve
GSS0816 is offline
Old 07-25-2007 | 10:30 AM
HiPerf2000's Avatar
The fuel pressure regulator has a small hose on it, and needs to pull vacuum from the underside of the plenum. there are a couple spots on the underside that you can unthread a plug and thread in a barb. maybe the guy just took the barb out.
HiPerf2000 is offline
Ted G's Avatar
Are you talking about the hole for #46 in this illustration:
http://www.mercruiserparts.com/Show_...+INTAKE+PLENUM
If you're using PCV then you need that 90 deg fitting, if not, you can plug it.
www.cbpba.com
Ted G is offline
Old 07-25-2007 | 11:03 AM
Ok, I bet that is what it was for, looks to be in the right place. If I chose to run a PVC, would I run it in the valve cover, like the cars do. What about the other valve cover opening, put a breather in it? Steve
GSS0816 is offline
Old 07-25-2007 | 01:59 PM
Ted G's Avatar
#31
http://www.mercruiserparts.com/Show_...D+ROCKER+COVER
www.cbpba.com
Ted G is offline
Old 07-25-2007 | 02:11 PM
Thanks, That's what I thought.
Steve
GSS0816 is offline
CHEKT OUT
3
12-06-2007 01:00 PM
GSS0816
10
07-04-2007 02:11 PM
thedonz
2
06-18-2004 01:19 PM
mrp
11
09-19-2003 08:05 PM
wwbobb
3
09-17-2002 09:26 AM
