No wash out drains
If you do decide to add your own, Be carefull on the port and starboard side of the cocpit towards the rear. The gas tanks are mounted right underneith, while I spent time in the factory I have seen an abundance in some cases of the tanks put in with too much foam, and the tanks rise as the foam did to where the the top of the tanks were rubbing on the underside of the cocpit floor. In some cases so bad, It would not allow the deck to sit down properly. Just an FYI. Check your Clearance.
The old owner Klym, NEVER put drains in any of the boats? Too much money for him I guess. LOL The 31's also have a problem of collecting water under the floor just as you enter the cabin where you first step down. Take a 2" hole saw. Enough clearance. I will bet you have water under the floor in the cabin as well. Just cover with an inspection plate. At the end there were so many complaints he used to put bildge pumps in that area. Being you have a 99 you may already have them there, I know he did not do that for every 31 that left the factory. If you have a inspection plate already there you most likely have pumps in that area. ( I would check to make sure they are still operatable.)
Cruzzin
Cruzzin
I know what your talking about, But there's no inspection covers anywere . My boat is store in my garage, And never had it in the rain , lucky for me . last weekend my buddy's were making fun at me because of the rain coming an me running my boat back into port. That sucks, going to try a fix
JBBEARD
you are gonna have to do the pumps. I try to ream out the drains where they were plugged by the gas tank install foam but could not get a drill to snake past all the problem areas. My 31 is from 1997 and had over 1500 pounds of water trapped in front cabin and sponsons. water comes in from cleats and rub rail screw holes so plug the holes and buy gasket and drain kit for your popup cleats- the water will kill your speed and mildew your cabin.
I have 1994 30 awesome also with no drains any where, not even in the transome. The cabin has had water standing in it more than once so you're saying I've probably got water under the floor of cabin and cockpit also. I was always concerned about this. I don't have any inspection plates
JBBEARD
Do you mean right where you step down into cabin ? how big a whole should I drill ? Do you know if this is all one section from gas tanks forward. Can shop vac it out ? I always wondered if water could be in this area I keep under covered slip in summer and carport in the winter but a couple of times while i've left it for work the cabin has filled with water.thanks for info everybody thinks its crazy that it has no drains
JBBEARD
JBBEARD
YEP! Its a Must do thing for the awesome 31
Thanks for info not sure of my ability to do this but like I said I had feeling something wasn't quiet right like a little extra trim on port and boat not as light feeling in water. This is the boat hot boat tested in 1994 I 've had 10 or 11 years 500 hours Thanks again
