Spare Tire Mount ?
Old 07-26-2007 | 02:55 PM
Default Spare Tire Mount ?
Looking for (2) spare tire mounts for trailer-
Sacred Ground is offline
Old 07-26-2007 | 03:21 PM
Strip Poker 388's Avatar
Rob
This is Myco's mount.This pick their not finished,just tack welded ,. He priced them to me for 140.00 painted.
The one that came on my Myco Trailer in alumium.Myco said they didnt make it .Ill try to get a pick of it,Its pretty neet looking.
Strip Poker 388 is offline
Old 07-26-2007 | 03:34 PM
t500hps's Avatar
21 and 42 footers
Buy the cheapest straight axle you can find that has the same spindle as yours. Cut the middle out and mount each side to each side of your trailer. Get new spindles and mount bearings, spindles, AND the spare tires to them. Now you have the entire hub assembly should you have problems on the road.
t500hps is offline
Old 07-26-2007 | 04:37 PM
Rob
good idear.Picks?
Old 07-26-2007 | 07:54 PM
t500hps's Avatar
21 and 42 footers
Originally Posted by Strip Poker 388
good idear.Picks?
No, I didn't do it but I'll get some pics....When I had my trailer built I asked for 2 hub mount spare tire assemblies. That's what they did and it worked great. The only problem is the wheels spin if you try to step on them to get on the bow.
t500hps is offline
Old 07-26-2007 | 09:47 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
That is a great idea. Even if you bought a torsion axle, and "cut the middle out;" you would destroy the torsion suspension of the axle, but you would have two spare removable spindles as well.
Sydwayz is offline
Old 07-26-2007 | 11:57 PM
Rob
Myco told me they dont make a spare tire mount that would hold the spare hub also.It a good idear.
I bet you could order a spindle from dexter,etc and bolt it on the mount, most spindle ive seen have a square flange that welded to the axel.
Old 07-27-2007 | 09:54 PM
bowtie's Avatar
I bought spindles from a local trailer distributor. Under 20.00 each, weld them on the trailer and you're set.
bowtie is offline
Old 07-30-2007 | 07:03 AM
boatman22's Avatar
Here is what I use:
Bottom right of page:
http://www.championtrailers.com/cata...20carriers.pdf
boatman22 is offline
Old 08-24-2007 | 10:39 AM
Thanks guys for all the help-see ya in Key West
Strip Poker 388
Swap Shop
10
06-10-2009 02:08 AM
Strip Poker 388
4
08-27-2007 11:30 PM
Steve_H
1
05-27-2003 10:18 PM
Intolerant1
07-31-2002 07:18 AM
290PQ
2
01-26-2002 12:21 AM
