Go Back  Offshoreonly.com > Owners Forum > Powerquest
Water Temp gauge on Enticer >
Old 07-30-2007 | 09:20 AM
Enticer Rick's Avatar
From: Lake St Clair Metropark, Harrison Township, MI
Default Water Temp gauge on Enticer
Just curious what you guys are reading on your temp gauges while running. I'm at 180, seem a little high?
Enticer Rick is offline
Old 07-30-2007 | 10:59 AM
I run 180 on mine when I am on it, slightly below when I am cruising and it bumps to 190ish when I come off plane and then cools off back to just below 180 on my gauges.
Both motors are the same temp. One warm sup slightly faster than the other but once they are up to temp they are dead even
I have 502Mags MPI
ckentling is offline
Old 07-30-2007 | 11:29 AM
Going by my factory Faria gauges I am just under the 175 degree mark.I was told to use the electric gauges more for comparison/watching for changes than counting on them for a hard number.
johnny b good is offline
Old 07-30-2007 | 01:30 PM
Knot 4 Me's Avatar
You are fine at 180. None of these gauges are very accurate.
Knot 4 Me is offline
Old 07-30-2007 | 02:26 PM
cbgenrl's Avatar
I run consistently at 165...and our lake temp tends to be warm due to powerplant cooling.
cbgenrl is offline
Old 07-30-2007 | 08:24 PM
I have 502Mags MPI
The 502 has a 176 degree thermostat so 180 is close considering the gauge accuracy. If mine shows 190 its time for a impeller.
Dave
Dave Kline is offline
Old 07-31-2007 | 05:31 AM
Another thing to keep in mind is faulty thermostates.I have had them stick open where the engine would run to cold.
masi242
10-23-2008 10:38 AM
rrentsch
Wanted
4
07-23-2008 01:29 PM
Ailina
5
05-19-2004 11:30 PM
Dave1972
2
03-31-2003 10:14 AM
Jana
7
07-29-2002 09:29 PM
