Motor Guys - Oil Pressure Drop Under High RPM >
Old 08-03-2007 | 07:53 AM
Matty439's Avatar
Default Motor Guys - Oil Pressure Drop Under High RPM
Running 570cid-600hp+ w/ high volume pump. Oil pressure during start-up,cruise 32-3600rpm, and once hot run great at 65-70psi. When I take engines up to 4000rpm - 5400rpm the oil pressure in the starboard motor drops to 25-40psi respectively to the rpm. Higher the rpm lower the pressure. Take the rpm back to cruise at 3200-3600 and pressure comes back to 65psi. When hot both motors idle at 50psi. Port engine rock solid at 70psi cold/running - 50psi idle. Starboard was the same until I pulled out of storage after this last winter. What is going on?????????
Matty439 is offline
Old 08-03-2007 | 07:55 AM
Sounds like you're sucking the pan dry or have a bad sending unit.
Griswald is offline
Old 08-03-2007 | 07:59 AM
articfriends's Avatar
Check true pressure with a mechanical gauge,cut open the filter and check for debris. A nice filter cutter is under 50$,I just bought one myself I liked crocketts so much,Smitty
Attached Thumbnails Motor Guys - Oil Pressure Drop Under High RPM-crocketts-dyno-2007-003.jpg
articfriends is offline
Old 08-03-2007 | 08:51 AM
Airpacker's Avatar
what do the oil temps do?
Airpacker is offline
Old 08-03-2007 | 09:02 AM
when you figure it out let me know, i have been having the same problem with one og my motors all summer
changed relief valves in blocks, replumbed oil lines. When i put a new filter on it is good for a day or two and then the problem comes back
djtalon is offline
Old 08-03-2007 | 09:06 AM
Maybe a cracked oil pick-up?
BenPerfected is offline
Old 08-03-2007 | 09:11 AM
Could also be windage. If the oil level is too high, the crankshaft counterweights are beating air bubbles into the oil, and sucked up by oil pump. I'd try dropping the oil level 1-2 quarts and do a short repeat just to see if it is the problem. If the problem actually then becomes worse, then you may need an improved engine oil cooler.
SmallPP is offline
Old 08-03-2007 | 09:49 AM
Windage, you need more low pressure area in the pan to disspate the high pressure created by the rotating parts. The fix is a larger pan.
cstraub is offline
Old 08-03-2007 | 10:01 AM
Would it make any difference if you increased the vent size at the valve covers?
Old 08-03-2007 | 11:01 AM
Breathers are upstairs, oil is downstairs. Your problem is in the basement. You can test to see if windage is the problem by lowering your oil level 1-2 quarts. Watch gauge closely and only do this for a short run.
SmallPP is offline
