Zero Effort throttle binding
Yes, very simple, just disconnect at the motor and it should slide in and out like butter. Also pull the levers out, or look inside if you can, and see if there is something in the way of the throw of the stick. Just a pin and a cotter key away from knowing.
Kevin,
I thought they were both binding when we loaded it after the Chicago PR. Did you try to loosen the nylock nut where the cable is attached to the throttle lever?
My Livorsi billet even shifted hard when I overtightened the nylock nut on the throttle lever.
Had the same problem with my shift linkage. I had leaned on it by mistake while working on the engine. Found the slightest bend in the sleeve at the end of the cable made it feel like a metal to metal bind.
I have Steps & Bubbles!
