BBlades Maximus 32P 5 Blades on the way... >
Old 08-08-2007 | 10:49 AM
Default BBlades Maximus 32P 5 Blades on the way...
After speaking with Brett, I have decided to try out the BBlades Maximus 32P 5 Blade modified props. Based on our conversation, it should pick up 4-5mph in the midrange cruising area and hopefully get at least 2mph consistently on top end.
I have some decent numbers with the box stock Bravo I 32P, so I am anxious to try out the new Maximus props.
I will post the results once the props arrive.
Viper TT is offline
Old 08-08-2007 | 11:02 PM
Rebel_Heart's Avatar
It will be interesting to see what speeds you pick up over a stock Bravo. Are the Maximus' going to be stock also? I have heard the Maximus needs to be labbed to be efficient. I didn't get to try one, so I'll be interested in your results.
Rebel_Heart is offline
Old 08-09-2007 | 07:24 AM
From what Brett and I discussed, the stock Maximus 32P would probably cost me 400-500rpms which in turn would reduce my top end by ~1-2mph.
He suggested having them labbed and the cutting down the diffuser ring to bring the rpms back up on top, so that is what I decided to go with.
The 3 week lead time is going to be tough!
Viper TT is offline
Old 08-09-2007 | 12:26 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
We'll get them done and to you ASAP.
By the way, my 10 year old son loves your avatar. He told me all about that car and what it is capable of. I'm so proud.
[email protected]
bbladesprops is offline
Old 08-09-2007 | 12:43 PM
Strip Poker 388's Avatar
Rob
I would think you would drop down in pitch to go with the 5 blades? Would doing the work to the Maximus 32p loose some efficiency[prop slip] compared to going with a stock set of Maximus 30P?
Strip Poker 388 is offline
Old 08-09-2007 | 02:20 PM
I went from a labbed 28 b1 to a...... labbed(merc) 26 max 5 blade. Gained 5 mph cruising at the same rpm. lost 1 mph on the top end. same day testing, same weight, same water conditions, same driver, same tabs/drive position. Just be carefull, they have a lot of BITE so your drive might not be very happy if you WOT it without the boat up on plane.
VegasHallett is offline
Old 08-09-2007 | 03:13 PM
I know my 5yo son is already a car junky! We've got an expensive future ahead of us! LOL!
If your son wants some video clips, let me know.
Viper TT is offline
Old 08-09-2007 | 03:16 PM
Interesting. You lost 1mph by decreasing the pitch and labbing.
Thanks for the warning. I normally just increase the throttles to around 3000rpms until the boat gets on plane, then begin to increase.
Viper TT is offline
Old 08-09-2007 | 03:38 PM
Brett told me the stock 32P B1 is equivalent to a Maximus 30P.
I'm not sure about the slip, but I'm sure labbing increases the slip.
Viper TT is offline
Old 08-09-2007 | 03:45 PM
SAme here. 3000 till boat on plane. the 5 blade has so much bite the slip % went way down. Not sure off hand what it was. something like 15%.
