circulating pump leaing spitting water >
Old 08-09-2007 | 10:33 PM
CHAOS REIGNS's Avatar
Default circulating pump leaing spitting water
i did a search and i don't see anything on my issue.
tonight while running the boat -- i noticed water on my engine hatch. upon further inspection i see water coming out of a small hole in the circulating pump. I'm assuming this is some sort of pressure releif????
what do i need to do ?
i ran the boat for about 10 minutes -- never got hot or anything -- but water still came out of this small hole
thanks guy's
Mark
CHAOS REIGNS is offline
Old 08-09-2007 | 10:53 PM
That hole lets you know the seal is bad and leaking across the bearing. The pump needs to be replaced.
Jim
MOBILEMERCMAN is offline
Old 08-10-2007 | 07:36 AM
i was afraid of that.
Old 08-10-2007 | 09:21 AM
Don't worry. It's a fairly easy replacement. New pumps are easy to find. Just be sure to get the marine version as it has brass and stainless steel internals.
Pull the belt(s), unbolt the pump, carefully scrape and clean the gasket area, add gasket sealant and bolt up the new pump. Takes less than 1 hour (and that's with a cold brew or two during the job!)
Holy Smokes is offline
Old 08-10-2007 | 09:41 AM
yeah it doesn't look too bad
i'm trying to track down a pump locally -- do you know who would carry such a thing?
i've called a couple boat repair places -- no luck yet
Old 08-10-2007 | 09:43 AM
i'd like to still go boating this weekend
Old 08-10-2007 | 09:44 AM
BY U BOY's Avatar
How about a crossover?
BY U BOY is offline
Old 08-10-2007 | 09:45 AM
NAPA has the Merc cross reference catalog. Hope that helps.
jeff1000man is offline
Old 08-10-2007 | 09:48 AM
Don't let it spoil your weekend, make sure you clean all the salt off when you finished. As far as boat problems go that is certainly a small one.
Jim
Old 08-10-2007 | 11:55 AM
I've gone this route a few times in the past. Not bad prices either.
Darrell.
DMOORE is offline
