Prop Interchangeability
I don't think that there are many similarities between alpha and bravo 1 prop shafts. The prop hub is what must be compatible with a particular prop shaft. The hub is a seperate piece on the Bravo 1 props. I don't know about the alphas.
This is why an X drive fits the same Bravo 1 props as an XR drive, even though the prop shafts are different on the two drives. The correct hub is what allows the same prop to fit either drive.
John
John
MIKEHTMSR24
07-22-2002 03:18 PM
