Changing Fuel Filter no gas available to fill >
Old 08-10-2007 | 09:33 PM
Default Changing Fuel Filter no gas available to fill
I have 1998 272 with 454 Mag MPI, I have a question, what do you do if you are changing your fuel filter and don't have gas to fill the new one with? I changed mine today and only had enough on hand to fill half of it. When I tried to start the boat, it ran for a few seconds then died, now it will not start, I am sure it will start after it sits overnight.
This happened once before, I didn't know you had to put fuel in the filter, I could not get the boat to start, left it over night and it started right up the next day.
So what can I do to get this thing started without waiting overnight? And exactly what causes this? Some kind of saftey check valve or just air in the fuel lines? How do you prime the fuel system?
wballant is offline
Old 08-10-2007 | 09:47 PM
vapor lock
try and turn the motor over and give a lot of throtle that mite do it
mikebrls is offline
Old 08-10-2007 | 10:23 PM
BY U BOY's Avatar
pull the coil wire off and turn it over 3 times for 12 seconds each time. That should be enough to prime the filter.
BY U BOY is offline
Pat Ousborne
Fountain
4
06-05-2008 08:10 PM
hunster
07-19-2007 12:49 PM
Sydwayz
05-26-2002 11:37 AM
Sydwayz
1
05-25-2002 02:09 PM
