496 mag problem???? >
496 mag problem????
496 mag problem????
Old 08-12-2007 | 08:54 AM
Default 496 mag problem????
I have twin '05 496 mags. Both start and run great.
At 4000 RPM port engine sounds hard alarm and enters guardian mode. Guages and fluid levels are fine. I have to throttle back to idle for the alarm to shut off, then everything is fine as long as I stay under 4000 RPM. If the water impeller was a problem, I think the alarm would go off before 4000 RPM.
cgharreell is offline
Old 08-12-2007 | 08:59 AM
hp500efi's Avatar
Member #9
you will really need to have a scan done to pinpoint the alarm.
If you wanted to, remove and swap the seawater pressure sensor from the non alarm motor to the alarm motor to see if that is causing the alarm. That was the case for me.
Member of the Liquid Jungle
hp500efi is offline
Old 08-13-2007 | 11:37 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Did you change or upgrade anything?? Like exhaust? Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 08-14-2007 | 09:14 AM
No uprades or changes. Might have to break out some money for the scaner, or find a local guy who wants to make a couple extra bucks with his scaner.
Old 08-31-2007 | 07:18 AM
I changed the fuel filters, and ran the boats again. This time when running I throttled up a little at a time, all the way up to 4700 rpm (wide open) and no problem! When I start from a idle, off plane, and gun it, the hard alarm sounds at about 4000 RPM, just as the boat is starting to plane. What sensors will cause the computer to go in guardian mode?
Old 08-31-2007 | 07:43 AM
Try cam sensors, and drive sensors. I just went through a similar situation. Starboard motor shuts off. It wiill start right back. Fuel pump issue. Fuel peassure was low System goes into guardian mode, but the sensos will record a failure data on the computers. See my posts on sim. issues with other threads. Good luck.
PARADOX is offline
Old 05-06-2013 | 09:04 AM
Any final answers on this one, I am seeing a simliar problem on friends 496 with exhaust work.
Mike L is offline
Old 05-06-2013 | 09:49 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Nearly impossible to say anything definitive without having it scanned. The Rinda is $500 worth it's weight in gold. I suggest going in with a few friends to share one.
Sydwayz is offline
Old 05-06-2013 | 09:58 AM
If I were to "guess" I'd say water pressure sensor has debris in it or the impeller is failing. I had same issue on my 496, replace impeller 3 fliping times, and also change the impeller housing. Finally I changed the sensor. Once I got the new sensor installed I tapped the old sensor on the the floor and a few grains of sand fell out of it.....
low_psi is offline
Old 05-06-2013 | 10:10 AM
For 350 bucks and your laptop you can view everything at once, even data log. Save your self a lot of time and aggravation, not to mention wasted money buying sensors based on a guess.
http://mefiburn.com/sc/details.asp?item=mefi5scan
4bus is offline
