Go Back  Offshoreonly.com > Owners Forum > Chris Craft
tow vehicle for 1984 stinger 260 >
Old 08-13-2007 | 03:19 PM
Default tow vehicle for 1984 stinger 260
Looking for advice on a tow vehicle. Was thinking about purchasing a new Ford Expidition that can tow a max trailer weight of 9,200. What is everybody else using to tow their stingers?
thanks,
Han.
hantunca is offline
Old 08-13-2007 | 04:14 PM
2000 F-250, pulls real good. a dually pulls it best
gbcoker is offline
Old 08-13-2007 | 04:42 PM
Full Force's Avatar
Anything 3/4 ton will be fine, a 1/2 would do it but a 3/4 has a lille extra beef.
Full Force is offline
Old 08-13-2007 | 04:52 PM
I tow mine with either a 3/4 ton big block Suburban or GMC CC dually big-block. IF you use a half ton truck, better have very good working electric or electric over hyd brakes. I would not recommend a half ton tow vehicle for a 260. Dry weight with no trailer is 5200 lbs. Add a trailer, half tank of fuel, a few meager boating accessories and your probably pushing 7500 lbs. or more. I would think that would exceed most half ton truck ratings. I know the proper tongue weight would. Remember that those tow ratings include the weight of you, your passengers, your gear, and then the boat and trailer. Besides, just because a vehicle can get the load moving and pull it, doesn't mean that you can stop or that it is especially safe to tow that much with it.
CCstinger260 is offline
Old 08-14-2007 | 12:34 AM
jeff32's Avatar
well equipped a half ton would do. 5.3 engine not 4.8. right gear ratio, good brakes on trailer and if needed, torsion bars, and you are good to go. I pulled mine weighing 9000 pounds full of gas, and ran fine... Of course, 3/4 or 1 ton is always better! but these trucks are generally rated, depending on options, between 7500 and 8500. the new GM'S 1/2 ton could now tow 10000 no problem according to books, so... hope it helps!
jeff32 is offline
Old 08-14-2007 | 06:20 AM
psmith's Avatar
psmith
I have a 3/4 ton Dodge with the Cummins, works out great.
psmith is offline
Old 08-14-2007 | 08:46 AM
Thanks for all of the advice. From Ford's website it says with the optional heavy-duty trailer tow capacity the Max GCWR is 15,000 and the Max Trailer Weight is 9,200lbs. This expedition comes with a 5.4L V8 with a 3.73 axle ratio. Seems like it could pull the boat. The trailer I have is aluminum with electric over hydraulic brakes. Didn't want to consider anything bigger as I don't have room for a larger truck.
hantunca is offline
Old 08-15-2007 | 06:54 PM
I have a 97 Expedition 4WD
It tows excellent and draws the boat out of the water in 4LOW very easily.
I have a class 4 Reese on the back with the factory seven prong plug.
ve3lt is offline
Old 08-17-2007 | 03:45 PM
That is about the same weight as my 245 limited. Chevrolet 2500 w/ 6.5 Turbo Diesel pulls it perfect.
I would not want to try with a 1/2 ton unless it was like the new F-150 that is more like a 3/4.
BootyPirate is offline
hantunca
Chris Craft
24
06-19-2010 09:11 AM
psmith
Chris Craft
4
09-18-2007 06:27 AM
point92mach
Chris Craft
0
08-20-2007 01:01 PM
hantunca
Chris Craft
1
07-05-2007 10:42 PM
ENGINESPLUS
Chris Craft
35
01-16-2006 11:56 PM
