Anyone Using Snaptraxx For Bunk Trailer? >
Old 08-14-2007 | 12:21 AM
jeff32's Avatar
Default Anyone Using Snaptraxx For Bunk Trailer?
here is the link
http://www.snaptraxx.com/
any good or bad comment on this product? I will need either this or carpet on my trailer so before I go, better ask before! Thanks
jeff32 is offline
Old 08-14-2007 | 12:42 AM
I had some rigid plastic bunk pieces like those on a trailer. Everytime I launched I saw more whit gelcoat powder where they were rubbing grooves in the gel. I took them off after a couple months.
WILDMAN is offline
Old 08-14-2007 | 07:12 AM
Tom A.'s Avatar
I saw them up at 1000 Islands and couldn't understand the benefits vs. the costs. I think the only way they might benefit is if you had a trailer with ill-fitting bunks and neeeded to completely change them. Just my .02
Tom A. is offline
Old 08-15-2007 | 09:28 PM
Default Snaptraxx
I am the inventor of Snaptraxx; I am also a boat builder. I developed Snaptraxx primarily to solve two major issues; 1 - Wet, slow drying carpet leaving gel coat blisters on my hulls. 2- Maintenance, I like to spend my time on my boats or improving them not changing carpet.
Snaptraxx consist of a plastic frame that totally encases the lumber and pads that make contact with the hull. The reason the frame and the pads are not the same plastic is because I needed to use softer more forgiving plastic to contact the hull and a more structural plastic in the frame to hold the unit together. Snaptraxx does not wear away gel coat like many of the other products out there.
Molding the pads separately from the frames allows me to vary the friction characteristics of the product. I currently have two styles available; "Grip Sections" and "Slip Sections". On my stepped hulls I primarily use the "Grip Sections". The hull must float free of the bunks before it can move so I like it to stay put as long as possible. The flats fishermen down south prefer all slip sections. The Bass fisherman typically put grip sections in the front and slip in the rear so they can power onto the trailer and then stay put. Benefits of Snaptraxx include; maintenance free, blister elimination, easier launch, they drain water away from the lumber to extend its life, simple installation and good looks.
Please give me a call with any questions and to receave a fellow performance boater discount 585-943-4212.
Thanks[email protected]
Attached Thumbnails Anyone Using Snaptraxx For Bunk Trailer?-boat.jpg   Anyone Using Snaptraxx For Bunk Trailer?-yellow.jpg
Ocean X is offline
Old 08-15-2007 | 09:40 PM
jeff32's Avatar
kingston gave you visibility for sure... that is why I asked on this board who was using them... nice product in my opinion...
jeff32 is offline
Old 08-16-2007 | 06:58 AM
Canada Jeff's Avatar
I like the idea, but to feel them, I thought they would scratch if you came onto the trailer in a less than perfect position. I can't say they would because I havn't used them, but they felt pretty dam sharp on the edge.
Ocean X, do you have pictures of the hull on your boat? Help eliminate this concern? How long have you been useing this on your trailer?
Another benifit may be for some boat lifts. Keep the sand and dirt off.
Canada Jeff is offline
Old 08-16-2007 | 07:54 AM
DaveP's Avatar
It looks neat. I have been involved in the hi performance marine business for 10 years now and I have never seen blisters that were cause by wet slow drying bunks on a trailer.
DaveP is offline
Old 08-16-2007 | 10:04 AM
I've always had VERY good luck with high-quality lumber, high-quality bunk carpet, and a light spray down of Liquid Rollers twice a season.
Always use Monel or stainless staples !
Jim
jafo is offline
Old 08-16-2007 | 12:05 PM
Johnny Venomous's Avatar
I love this stuff but I wish I could afford it, I need four 22ft. sections for my cat trailer bunks (tops and sides). Not happening at that price. Almost $2000 OUCH!!!
Johnny Venomous is offline
Old 08-16-2007 | 01:19 PM
Tom A.'s Avatar
Ditto to posts #6,7,8.
Tom A. is offline
