Bravo Vs Hydromotives
I need a set of new props, 25": or 26". for twin 496 set up. Bravo I's
In head to head ... which make will give me better top end?
Is there a comparison done anywhere?
Is the labbing process worth the $ ???
Thx
Thx
Question for you:
So how do the 25p QIV-Xs compare to the 26p B1s as far as performance.
I have yet to try a QIV-X on my boat but I have run many different 4 blade props.
A modified B1 has proven to be the best over all and fastest 4 blade to date on my hull.
Patrick
Patrick
I haven't had the time to run them with my boat setup correctly. I just dropped motors a notch which is 3/4 inch and corrected toe...
Prior to that check here but the jist of it is they were pretty much the same prop.
4 blade
15" diameter (B1 says 15.25 but my tape measure says 15)
4 blade
