300 Pro Max Done In...
Registered User
Blew up our stbd motor on our 2004 30' SPECTRE
#6 injector leaned out and pushed the connecting rod through the side of the block! Has anyone else seen this?
Why did this occur... If anybody knows where to source out a short block I'd appreciate the help!
Happy Boating!
Happy Boating!
had same problem w 300pm, it turned out the ethanol fuel didnt get along with the rubber in the low pressure fuel pump (the new merc fuel pump rebuild kit uses plastic disks instead) this in turn didnt feed enough fuel to the vst high pressure pump which leaned it out at high rpm -also check vst filter.
Registered User
We've had some idle issues! It likes to cut out obviously when cold & when shifting. A Mercury Rep told me to run their Quick Clean. I think I'll send the injectors out to be balanced! Do you have their contact info?
Thanks,
Thanks,
Don
Not runnin' ethanol fuel but, will check the fuel pump pressure and the VST high preasure pump as well...
