Benefits of prop labbing
Pirate of the Chesapeake
What are the benny's of this. Is it worth the money for it, can you pick up any mph from it or is is just help make it more efficient. Thanks John
Typically Lab Finishing is performed to gain top end. It allows you to step up to a taller pitch propeller (1-2 inches) and turn it at the same RPM as that of the smaller pitch propeller. You will typically see about an average of 250 RPM increase over its RPM when tested stock. There are some downfalls to labbing as well, which I have outlined on my web-site.
www.throttle-up.com
Click on services and then Lab Finishing
Julie
www.throttle-up.com
Julie
Lab Finishing has become a generic term like Kleenex is to tissue.
It wasn't meant to be that way. In fact, while I was still at Merc Racing we tried to Trademark the term but it was too late. We ended up with Mercury Lab Finished as the trademark.
Lab is short for laboritory and Mercury was the only game in town doing the original Labbing till 10 or so years ago. My old boss and his invented and perfected the process. In fact, till a few years ago they were the only ones who really understood the ins and outs of the processes. That can be seen by looking at the progression in some shops work over the years. Early prop work may be less than desired. It takes time to understand and learn propellers, you don't become a expert in a couple years
Mercury had the edge on everyone because they invented the process. There was a standard Lab template which was used for most all applications. Slowly we began modifying the process to make it what it is today.
So as more people began to work on customizing propellers, and because the performance gains were obvious, everyone started to say they were Lab Finishing the prop. Whether they actually knew what they were doing or not.
As it was before and as it is today, Labbing isn't always the best solution. At least not a generic Lab. Each application must be set up on its own merits. The best prop on the boat is the best prop on the boat whether it is investment cast or CNC'd doesn't guaranty anything. Either production process can surpass the other in performance on any given day on any given set up. Knowing the goals desired and adjusting the prop to meet those goals is key.
Pass me a tissue....I mean Kleenex!
B
B
[email protected]
[email protected]
