29 outlaw
Just bought a 29 this spring, traded a 25. It has 454 carb. mags with 460 hrs. They run great, and use less oil than my 502 in my 25. Should I freshen them this winter, or just keep running them? Also bought a near new set ot 3 blade 25 mirages, would this be a good choice for ths boat, or should I send them out and have them labbed?
What year is the boat, 97 or older?
I have MPI's and am running 23's and they seam to work quite well, quick out of the hole and around 65 top end. I think 25's might be a little too big. What do you have on there now and how do they run?
460 is getting up there in hours. I'd run a compression / leakdown test before doing any work. They may be fine.
I wouldn't touch the motors but that's me. I have a buddy with the same motors as you and he has almost 800 hours on it and hasn't touched em. I run 25, 3 blades on mine and like em. Good top end and a stable ride. I would like to try a pair of labbed, 28 pitch, 4 blades.
Baja Fresh, The boat is a 1998, im surprised it doesnt have fuel injection. I like the boat, but now I see in the classifieds, there is a 98 with injected mags for 47k, I gave 50 for this boat without hyd steering. You always find a better deal after you buy something. What do you do? I looked around all winter, and was going to do a deal with Hawkeye on 98 with 502s, which would have been an awesome boat, but it would have worked out so that I was giving about 67 with my 25 trade, I was not willing to do that, I would have been buried in that boat.
502's would be nice though! I thought all the '98's were injected. maybe your's is a very early 98 or something.
Dont go through the motors.....Save throwing a rod through the block it's not going to cost more to rebuild them if they blow than it will right now. Get what you can out of 'em. when they go, then re-build.
(whats up Al!?)
(whats up Al!?)
