300 X beeps 4 X's >
300 X beeps 4 X's
300 X beeps 4 X's
Old 08-17-2007 | 08:56 PM
36spectre's Avatar
Registered User
Default 300 X beeps 4 X's
HELP>>>>>>
one of my my 300's continually beeps 4 times .........
it does it at first start up, and while running at various speeds and times.
it can run for 20 minutes and then beeps 4 X'sor every 5 minutes.
5 gallon oil tanks are full as well as the reserve.
varies from 8-12 lbs. water pressure while running.
engine temps. are from 140 to 150 degrees.
12 volts plus.
IDEAS????
Thanks......................
otto
36spectre is offline
Old 08-18-2007 | 01:09 AM
Go ask on Screamandfly.com somebody will know
fishead is offline
Old 08-18-2007 | 09:22 AM
berns29scarab's Avatar
do you have a smart craft system ?
berns29scarab is offline
Old 08-18-2007 | 12:00 PM
4 beeps is oil.....1st check which is the motor that is beepeing, then look on top of the oil tank on the motor you will see the sensor which drops in the tank, swap them over on each motor then see if it still beeps...if it doesnt, the oil sensor is bad just get a new one and its a $20.00 fix if not then swap the complete tank, sometimes the tanks magnet on the bottom of the go bad.....
lowblue320 is offline
Old 08-18-2007 | 02:14 PM
WHAT HE SAID...and also make sure that the tank on the motor is FULL TO THE RIM !!!
Old 08-18-2007 | 09:18 PM
4 beeps is also water in the gas. Drain the water separater on a 300x or the vapor canister on a 300xs. If the oil tank on the motor is full then water is most likely the problem.
WILDMAN is offline
Old 08-19-2007 | 06:31 AM
36spectre's Avatar
Registered User
the answers was to fill the reserve tank to the tippy tippy top.
it'sperfect now!!
THANKS EVERYONE!!!!!
Otto
Old 08-20-2007 | 10:32 AM
Talking 5 beeps
5 beeps is when you REALLy have to worry, lol. means your warranty is up. LOL
CanDo is offline
Old 08-20-2007 | 07:39 PM
36spectre's Avatar
Registered User
that was with the first beep!!
Old 08-21-2007 | 12:34 PM
TUFFboat's Avatar
Remember to tighten the inside oil bottle caps very tight, or else the oil will only draw from the little bottle at the motor.
TUFFboat is offline
Panther
Apache
22
12-05-2007 01:10 PM
cowisl
10-17-2005 07:10 PM
WETTE VETTE
08-29-2004 12:15 PM
timucin
04-22-2004 06:10 PM
Velocity Tom
09-09-2003 07:20 PM
