What broke?  Any ideas? >
Old 08-18-2007 | 10:41 AM
BillR's Avatar
OSO Moderator
Default What broke? Any ideas?
Looks like something is wrong w/ one of my outdrives.
Was about to run a poker run, opened to motor hatch while idling in gear and heard knocking. Troubleshooting - found out it is not the motor.
One of my drives knocks in forward. Put in neutral or reverse - it sounds fine. Back into fwd and the knocking occurs. The drive works; I ran back home 10 miles or so on plane 3500. After coming off plane - knocking was same - no worse.
What is the likely cause?
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 08-18-2007 | 03:27 PM
Trippin's Avatar
Check drive oil for contaminants. If lube is clean then you may have prop slap which is not a detrimental issue. Upgrade to a flo-torque type hub design. Not applicable to SSM'S if thats what your spinning.
Trippin is offline
Old 08-18-2007 | 05:38 PM
What drives?
MOBILEMERCMAN is offline
Old 08-19-2007 | 09:09 AM
BillR's Avatar
OSO Moderator
It is not the props.
Bravo XR's.
I'm thinking I chipped a tooth. . .
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 08-19-2007 | 09:27 AM
obnoxus's Avatar
Charter Member #1171
Bravo XR's.
Thats what it sounds like.Pull the top cap and see whats going on.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 08-19-2007 | 04:08 PM
BillR's Avatar
OSO Moderator
Pulled top cap - metal chips everywhere. Didn't dig any further.
Looks like front seal behind U-joint let go too. Leaks oil from there.
Off to get fixed . . . . . . .
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 08-20-2007 | 08:46 AM
KAAMA's Avatar
Bill, just curious as to what kind of power you're running in front of those XR's and how many hours you have on the drives? Thanks
KAAMA is offline
Old 08-20-2007 | 09:39 AM
Smitty's Avatar
I think he has 575's ??
Smitty is offline
Old 08-20-2007 | 03:13 PM
Kelly O's Avatar
Just went through this. Took a tooth clean off a gear in the upper and heard the ticking. Not too much for fragments in the oil, but broken piece did make it into the lower gears and put a mark in them.
New gears and bearings.
Quiet mufflers saved me from grenading the whole unit.
XR behind 950 hp. Lived 35 hrs. RIP!
Kelly O is offline
Old 08-21-2007 | 07:24 AM
BillR's Avatar
OSO Moderator
Kaama,
575SCi's that have 628 HP.
The upper part of drive has maybe 150-200 hours. The hours on the lowers is unknown.
Dropped the drive off w/ Excursion and he'll check them tonight.
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
