1995 Sr-271 Indy
New To Power Boating And The Forum. Looking At A 1995 Sr-271 Indy Edition. Powereed By A 502. Anything In Particular I Should Look For And Any Feedback On Pro's And Con's Would Be Appreciated.
Thanks In Advance.
Thanks In Advance.
The '95 Indy is just like every other 1992 thru 1996 271SR1 with only a few exceptions. It was the only 271 to date that had K-Planes from the factory. Unfortunately they are the long discontinued 110S model. If the trim tabs don't work parts may be an issue. The sunpad oval w/ the wheel and wings logo is a really intricate piece of upholstery that if you step on often you run the risk of spliting its seams, so look at its condition. McCleod will be happy to make a new one. For $1500.00 or so. All of the decals that are unique (port dash, intake manifold, midship above the rubrail, etc) are unobtainium. The engine components that are most visible were painted either green, purple, or maroon same as the colors on the outside of the boat. All of the engine's H2O hoses were covered in decorative braided stainless. Whatever parts that have been replaced (alternator, manifolds/risers/elbows, ps pump, sea pump, brackets, etc) will come out of a Mercruiser box painted black or not at all.
The '95 Indy model had every option included except the docking lights, bimini, or full enclosure. And all of them had the painted up 502mpi. Drive ratio could be 1.50 or 1.65. The two other years of Indy models ('96,'97) it was the graphics only in '96 and red gel plus graphics in '97, no options included that you didn't order, and pick your power that was painted black. Formula says they made 20 in 1995. I think there were far fewer made for '96 and '97.
The SR1 hull still had a good bit of wood used in their construction, so a survey would be a good idea. The legroom on the portside is a bit tight for tall people and don't plan on overnighting unless you are a midget.
The only place I'd be concerned would be the engine compartment/transom area and that is only if lots of water was left in the bilge for extended periods of time. The front bulkhead just ahead of the bilge pump and the area around the drain plug is where I'd focus. Also, the two L brackets that support the silent thunder are through bolted through the transom. They are sealed by o-rings between the bracket and transom. Even though it is above the water line, I would make sure the o-rings are intact. If the boat has been well taken care of (not sunk or left in the rain for years with the plug in) it should last forever.
Charter Member #415
They were pretty neat boats.I wouldn't worry about the sunpad vinyl,Formula stuff lasts a long time,and a good upholstery shop might get fairly close to the design.Same on the special decals. Todays computerized graphics guys can duplicate almost anything. We sold 2 of that particular model. Not exactly collectible,but close,doubt 20 were built.
Charter Member #415
My memory is a little fuzzy here (been a long time) but I believe I bought that boat. Seems that he had sponsorship ties with Ford and he needed Ford power,and Formula decided it would be easier to just build him another boat and let Arie supply the engine for the replacement,so I bought the one he won. Maybe someone with a better memory than I can add details.
