Depth sounder for step hulls >
Old 08-21-2007 | 03:51 PM
Registered User
Default Depth sounder for step hulls
I'm looking to install a new sounder, because I've not been able to find the "sweet spot" for a good shoot thru location for the transducer. The one I purchased from West Marine seems to be a decent product, it's a "Hawkeye". I get depth readings when off plane, but as soon as I start to get on plane, depth goes away. I know it has to do with the steps, & I've got it mounted about 6" from the transom, & up from the keel. I've moved it 3 times, & the readings are the same. Perhaps I need to go to a different brand, or am I just going to have to bite the bullet & go to a transom mount. I am really trying to avoid that, but I may not have a choice. Anyone have the same trouble with the ZX, or any other stepped hull? I have considered mounting it in the forward bilge area, in front of the steps, but just not sure what, if any reading when on plane....Any tips will be greatly appreciated....
rangerrick63 is offline
Old 08-21-2007 | 03:54 PM
I have a step bottom and put a transducer that shoots thru the fiberglass. I put the transducer half way up from the transom and glued it to the fiberglass. No drilling or modification needed. It works great and is out of the way.
VegasHallett is offline
Old 08-21-2007 | 04:02 PM
Registered User
Unfortunately, I tried that first, & I get the same reading. The one I have now is epoxied to the floor, I've also tried silicone, & no difference.....Thanks for the input
Old 08-21-2007 | 06:01 PM
masi242's Avatar
What kind are you using I`ll be looking for one soon.
thanks
masi242 is offline
Old 08-21-2007 | 09:16 PM
Tinkerer's Avatar
You have to install the transducer in front of the first step.
The air bubbles created by the steps stop the unit from working.
Tinkerer is offline
Old 08-21-2007 | 09:22 PM
Registered User
I looked this evening, it will be rather easy to move it up to the front bilge compartment. I'll move it & let ya know how it reads when on plane.
Old 08-21-2007 | 10:02 PM
Tinkerer's Avatar
Also if your hull is cored ( bulsa or other ) the builder usually will have a spot with solid hull to mount the transducer.
You can't shoot through a cored hull.
Tinkerer is offline
Old 08-21-2007 | 10:15 PM
Dean Ferry's Avatar
BINGO,
That's the correct answer!
Dean
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 08-21-2007 | 10:17 PM
cuda's Avatar
In my opinion, all a depth finder does, is confirm the fact when you are hard aground.
cuda is offline
Old 08-21-2007 | 10:21 PM
Originally Posted by Dean Ferry
BINGO,
Dean
True but he does get a reading, just not while on plane. I don't believe this is his problem. I say go in front of the step as you plan.
Brandon
Brandon is offline
