MPI and horse power
Old 08-22-2007 | 10:28 PM
Default MPI and horse power
how much HP can I get out of a 502 mpi till the MPI is maxed out and I have to change my induction system
nkdski is offline
Old 08-23-2007 | 12:13 AM
articfriends's Avatar
Depends what you mean when you say "maxed" out,I just dynoed my 540 with a 2000 502 mpi manifold and made 657 hp and motor is only 8.2-1 compression. The throttle body was bored out,I built twin rail fuel injection and used bigger injectors plus the manifold was ported. I am using 315 cnc afr heads also but also the cam was a blower cam so it probably could have been better with the right cam and more compression. A 540 is 7.1% bigger than a 502 which tells me my top end could have still made 620 hp on a low compression 502,Smitty
articfriends is offline
Old 08-23-2007 | 05:55 AM
mopower's Avatar
Toxic FORMULA
A friend of mine just did a 502 MPI into a 540 and ported the intake and had the ECU remapped and dynoed 600 HP.
mopower is offline
Old 08-23-2007 | 09:06 AM
how fast does the 272 go ow with a 540
nkdski is offline
Old 08-23-2007 | 06:51 PM
mopower's Avatar
Toxic FORMULA
Low 80s , but I have a low X dimension and not enough money for Imco "shorties"
mopower is offline
Old 08-24-2007 | 12:47 AM
My 2000 272 runs 78 mph (gps)(light) with the 657 hp set-up,turning 26 pitch labbed at 5500 at 680 ft elevation,76mph (gps) with it fairly loaded down,Smitty
Old 08-24-2007 | 01:52 AM
I just changed my 502 to a 540 and kept the side mounted whipple. It just dynoed at 825 with over 860 pounds of torque. We installed a 2000 cfm throttle body and holley intake, however we still used the top hat of the MPI intake. Check out the thread "One of a kind 502 rebuild"
The stock intake system and small throttle body is the major limiting factor.
VegasHallett is offline
osen007
4
06-13-2007 01:16 AM
LubeJobs42
01-29-2006 08:23 PM
Active Mike
7
11-09-2004 04:15 AM
sonic28
28
11-27-2003 04:47 PM
loosecannon22
01-07-2003 08:44 AM
