Who has the new Merc 383?
Old 08-24-2007 | 02:07 PM
BOOSTEDSCARAB's Avatar
Default Who has the new Merc 383?
I am looking for some info on this package. The merc add says it comes with a Bravo Transom Assy,....what exactly is included? Is it the comple gimbal assy and rams....or?
Any info would be great...thanks.
Dave-
BOOSTEDSCARAB is offline
Old 08-24-2007 | 02:26 PM
Stormrider's Avatar
JC Performance Engines
I know bam had them at one time...not sure of the new ones.
Stormrider is offline
Old 08-24-2007 | 02:28 PM
hey rob,...yeah I'm talking about the new ones offered as remans. A few guys on here have bought them from BAM....
Old 08-24-2007 | 02:30 PM
Stormrider's Avatar
aaahhhh... knew i'd find it.
http://www.offshoreonlyclassifieds.c...o11937-en.html
Old 08-24-2007 | 03:05 PM
When I bought my package it came with engine,bravo transom package, exhaust housing, power trim pump,bravo 1 out drive and all hoses. In other words a complete motor/drive set up less wiring harnesses, control, cables, ets.
boatnuts is offline
Old 08-24-2007 | 04:34 PM
Tantrum's Avatar
What was the housepower rating of the 7.4?
Tantrum is offline
Old 08-24-2007 | 06:10 PM
I have outdrives already,..merc makes it sound like if you buy just the engine package it comes with the bravo one transom assy..
This info was cut and pasted from the quicksilver/reman web site...it's 1/2 way down highlighted in orange
383-MAG STROKER ENGINE
350 Crankshaft Horsepower
Due to its size and power, this is an ideal replacement engine for the old 454s
1-Year factory warranty
Available at any Mercury/MerCruiser authorized dealer
2 additional years of coverage
Available from Mercury Product Protection
Dynamomoter Tested Utilizing Approved SAE - J607 Specifications
GM 350-Gen+ Longblock
Block deck is inspected and milled as required to help the gaskets seal.
Crankshaft Main-Caps are line-honed for straight and true rotation.
Forged Steel Stroker Crankshaft
Forged Powdered Metal Stroker Connecting Rods. (mass-matched for balance)
Marine Oil Pan
Dipstick Assembly (starboard-side)
5-Quarts of MerCruiser 4-Cycle 25W-40 engine oil
Top-Mounted Remote Oil Filter Assembly
NEW 3-Piece Full Roller Timing Set
Front Timing Cover
Cam Bores have Production Bearings Installed and Machined to Spec
Roller Camshaft is carefully inspected and highly polished.
Remanufactured Roller Lifters (including new roller bearings)
Cylinder Heads resurfaced for enhanced gasket sealing
100% NEW Stainless Steel Valves (intake & exhaust) (oversize-stem)
Machined Valve Guides to accommodate new Stainless valves
New Valve Springs
New Valve Stem Keepers
New Stem-to-Guide Seals
Metal Center-bolt Valve Covers
Water Circulating Pump
Alternator
Sea-Water Pump
Power Steering Pump
Serpentine Accessory Drive Belt
Belt tensioner(s)& pulleys
Thermostat Housing
Water Circulating Hoses with Multi-point drain system
Bravo Transom Assembly
Complete Installation Instructions
High Volume Oil pump
Hypereutectic Pistons with Grafal (Graphite) coated skirts
Moly Faced Piston Rings
Clevite 77 H-Series perfomance engine bearings
Marine Grade Gaskets and Seals
Brass marine-grade block plugs
Harmonic Balancer
Flywheel
Starter Motor
Electric Fuel Pump
Cool Fuel Kit
MPI intake Manifold
MPI Fuel Delivery System
Flame Arrestor
555-ECM(Capable of supporting Smartcraft technology if desired)
Distributor Assembly
Spark Plug Wires
Spark Plugs
Sterndrive Oil-Level Reservior / Indicator
Engine Mounts with Installation Hardware Kit
Style 1: Bell Housing / for Sterndrive applications with Coupler
Style 2: Bell Housing / for inboard applications with Coupler
Exhaust Manifolds
Exhaust Elbows
Exhaust Y-Pipe
Exhaust Mounting Hardware
OPTIONS PURCHASED SEPERATELY:
Closed Cooling Kit
Bravo Air-Actuated Water Drain System
3, 4.7, or 6 inch Exhaust Risers
Bravo I, II, or III Drive Assembly
Notes:
*Image above includes all available options
*DTS technology is not an optional accessory for this engine assembly.
Old 08-27-2007 | 01:28 PM
Arrow
In this ad , it's clearly stated what the complete package costs
http://www.mercruiserparts.com/383_Magnum.htm
spectras only is offline
jmherbert
0
07-29-2008 01:03 PM
rdoactive
13
01-07-2008 06:45 PM
brian valery
2
07-15-2007 10:25 PM
jmherbert
21
05-30-2007 03:30 PM
brian valery
7
05-10-2007 05:21 AM
