QIV slow to plane? >
QIV slow to plane?
QIV slow to plane?
Old 08-25-2007 | 09:08 AM
Default QIV slow to plane?
Read a few posts that said twin step foutains liked Hydromotive props so got a chance to try a set of 28P. I am now running 30P B1's. Got about the same WOT speed but was on the limiters so a taller pitch would give me some benefit but they were very slow to plane with a lot of blow out. I could get up without tabs but I really had to feather the throttles. B1s don't have that problem at all.
I did go from 16% - 14% slip @ WOT with the QIV so I can give "props" to that.
Just wondered if anyone else experienced the same?
gofastlvr is offline
Old 08-26-2007 | 09:18 AM
I had a lot of slippage with the Hydros. IF the boat is set up right, you will get more top end. THe B's have a bit larger surface area and not true to the pitch. A 30P B's is actually like 29 or 28.5. Easier to get out of the hole and plane out.
I'm still experimenting with B's and hydros. Grrrrrr
I will try airplane props next.
PARADOX is offline
Old 08-26-2007 | 09:38 AM
Same experience here. The QIV's are faster but they are geared for top-end vs. hole shots. Try the 30 QIV's; everything shoud improve vs. the 28's. Carder
Carder is offline
Old 08-26-2007 | 07:59 PM
Do the Hydro's have the rings welded on the hubs?
BenPerfected is offline
Old 08-26-2007 | 08:06 PM
The Hydromotives have always slipped more coming up than round ears like Mirage and Bravos but doesn't really matter if they run better once on plane. To some extent every option involves some level of compromise.
Jim
MOBILEMERCMAN is offline
Old 08-30-2007 | 06:11 PM
They are straight hubs.
doright
29
02-11-2011 10:12 PM
Donzi Corleone
05-30-2008 06:44 PM
Dono
2
05-29-2005 08:09 PM
Here's Johnny
07-06-2003 04:08 PM
