K plane ????'s
Old 08-28-2007 | 06:37 PM
DirtyMoney's Avatar
Default K plane ????'s
Will a 380 plate replace a 280 by just swapping plates?
DirtyMoney is offline
Old 08-28-2007 | 06:41 PM
Wally's Avatar
Were doomed!
yes
-Wally
Wally is offline
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Mine did with no issues. However there was a post not long ago about different generations having different width cylinders causing conflict.
Sydwayz is offline
Old 08-29-2007 | 12:02 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Yes.
Fenderjack is offline
Old 08-29-2007 | 06:10 AM
You should check them for clearance at full steering.Turn the drives to full lock and run both the tabs and drives up/down looking for interference. When I moved up to 380's,Diamond Performance cut them to clear my Number 5's. I've heard that Mercury has a template for this. As I recall, running a staggered set up is usually a clean swap. Fior what its worth...
Lmarth is offline
eeasy
5
07-29-2008 10:02 AM
Craney
4
09-11-2005 10:24 PM
Shah Mat
06-21-2005 08:49 PM
mtgbiker
2
04-21-2005 02:54 PM
blue64drop
6
11-11-2002 11:46 AM
