cleaning boat bottom with olympic deck cleaner ? >
Old 08-29-2007 | 01:42 PM
Default cleaning boat bottom with olympic deck cleaner ?
Anyone ever try cleaning the algee/slime off a boat bottom using Olympic deck cleaner ?
It's a lot cheaper then On-Off and biodegradble. The label says it is good for vinyl siding. I'm thinking of trying it on a small section of the underside.
ed
Interceptor is offline
Old 08-29-2007 | 01:59 PM
t500hps's Avatar
21 and 42 footers
God Luck....I find a mild solution of bleach and water does better than the store bought deck cleaners. I'm convinced bleach and water is all that is really in those bottles anyway.
t500hps is offline
Old 08-29-2007 | 07:23 PM
For algea, slime and stains on the bottom just use muratic acid. $4 a gallon. Pressure wash it first, then spray on the muratic with a pump garden sprayer. Rinse VERY well, especially the trailer. Also, do it in the street, the acid will eat/discolor your driveway.
Griff is offline
Old 08-29-2007 | 07:38 PM
It will also seriously kill your grass, flowers, or what ever else that might be growing.
baywatch is offline
Old 08-29-2007 | 09:21 PM
zitoracing's Avatar
gcoffshore.com
muratic acid is what I use to clean the brown off of my boat bottom
zitoracing is offline
Old 08-29-2007 | 09:24 PM
Go easy with muratic acid. I've seen boats that were cleaned with it on a weekly basis and the gelcoat looked like crap. Got real rough and stained way easier.
jmeng is offline
sleeper_dave's Avatar
Double bonus. Then I don't have to mow, and I can spend more time using the boat!
sleeper_dave is offline
Old 08-29-2007 | 09:33 PM
Muriatic acid plus a little soap helps keep it from running off so fast. Some people use a scotch bright pad. I think that is a mistake use a soft brush. jmeng witnessed problems with gelcoat probably more to do with scratches for cleaner pads than the chemicals. Been using acid on bottoms for many years without problems.
Jim
MOBILEMERCMAN is offline
Rambunctious
05-13-2013 12:02 PM
LS1 MOLESTER
29
09-17-2006 04:35 PM
Chris288
08-05-2005 04:34 PM
MILD THUNDER
07-22-2005 07:08 PM
gripit
Detailing, Painting, & Fiberglass
0
04-21-2005 07:21 PM
