Bulldog / 7.4L TB-V Ignition Experts; Question >
Old 08-30-2007 | 10:36 AM
Nordicflame's Avatar
Default Bulldog / 7.4L TB-V Ignition Experts; Question
I am going to be upgrading an 1996 7.4L Gen 6 carb motor (0F810161)
to a 489 stroker 10:1 CR with new AL heads and all.
I have a take off ignition module 848821 off of a 1996 Bulldog that I would like to use on this build. This is also the same module is used on the HP500 carb motors.
• Is this just a simple module swap? I see that the distributors are slightly different (Bulldog 805185A43 vs 7.4L 805185A36) but all else looks the same.
• Also is this just a simple 20* module and where is the rev limit set?
• I’m assuming that this does retain the timing assist as well, correct?
Any help would be appreciated…
Thanks,
Dave
1996 7.4L GenVI Carb TB-V
http://www.mercruiserparts.com/Show_...CAL+COMPONENTS
1996 Bulldog TB-V
Nordicflame is offline
Old 09-04-2007 | 08:32 AM
No One????????????????????
Old 09-04-2007 | 08:58 AM
The limiter on the 500's was 5300-5400. I can only guess it will work. I would think someone has swapped that and will respond.
Jim
MOBILEMERCMAN is offline
Old 09-04-2007 | 09:03 AM
Pat McPherson's Avatar
I know guys that have swapped the module on 7.4s to the 454Mag. Those two engines use the same distributor though.
Patrick
Pat McPherson is offline
Old 09-04-2007 | 09:29 AM
I think the difference is length, isn't the 540 a taller deck height?
Wild
MTI (Marine Technologies)
49
07-23-2008 01:15 PM
bsc
3
05-17-2006 02:09 PM
drypipetiger
12-23-2004 09:18 AM
Minx20
29
12-20-2004 02:09 PM
