Mud Flaps
Old 08-31-2007 | 10:27 AM
carter38's Avatar
Default Mud Flaps
For those of you that have lifted trucks I was wondering how many of you had made custom mud flaps to put on while towing. I have seen it done but never went and looked at how they where mounted. Any suggestions would help.
carter38 is offline
Old 08-31-2007 | 10:34 AM
BY U BOY's Avatar
I have seen people make these fairly cheap.
http://www.realtruck.com/productline...mud_flaps.html
this link gives better pics.
http://www.amazon.com/Adjustable-wit.../dp/B0007M6OUG
BY U BOY is offline
Old 08-31-2007 | 10:36 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I had this on my last truck. Now that I have a dually, they are not the correct width, but I still keep them around just incase.
http://www.mudflaps.com/
I bought the molded mudflaps that screw inside of the fenders of my dually, and then I extended them downward with another couple pieces of stiff rubber mudflap bolted to the bottom of them.
Sydwayz is offline
Old 08-31-2007 | 05:44 PM
sleek1's Avatar
I went to a semi-truck shop and bought the flaps, L-brackets, and bolts. Made my own with a cotter pin so I could remove the flaps when I didn't want them on the truck.
sleek1 is offline
Old 08-31-2007 | 08:41 PM
TOMMY HIWAVE's Avatar
i put two screws into plastic wheel liner and two zip ties around metal rod that holds fender works great.
TOMMY HIWAVE is offline
Old 09-03-2007 | 09:54 AM
carter38's Avatar
Thats what I am after thanks man.
carter38 is offline
Old 09-03-2007 | 12:58 PM
Smitty's Avatar
here are some pics of my set up. It is a really stout piece. It is all heavy duty. Buck saw it at LOTO. ask him what he thought about it. P.M. me if you want more info, I can get back to you tuesday.
Smitty
PS My truck has a 4" lift. Also are your flames painted or vinyl??
Attached Thumbnails Mud Flaps-flap1.jpg   Mud Flaps-flap2.jpg   Mud Flaps-flap3.jpg
Smitty is offline
Old 09-03-2007 | 03:59 PM
carter38's Avatar
Thats something I'm after any info would help and the flames are painted.
carter38 is offline
Old 09-03-2007 | 10:13 PM
Smitty's Avatar
Give me a call tomorrow somwtime at 847 774 7182
Smitty
Smitty is offline
Old 09-04-2007 | 03:56 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
A cheap and quicky I made from some scrap angle and mud flap from a TSC store. Clamps right on the hitch.
US1 Fountain is offline
BadDog
9
11-09-2004 06:37 PM
rouxsterre
2
04-18-2003 07:17 PM
