Go Back  Offshoreonly.com > Owners Forum > Sea Ray
Trim tab help >
Trim tab help
Trim tab help
Old 09-02-2007 | 03:42 PM
Default Trim tab help
I want to put tabs on my 87 22' with 454, can I get some input what size tabs others are using on there 22's? How does one typically decide the best size tabs for their vessel?
wet_rat is offline
Old 09-04-2007 | 11:51 AM
I'm running bennet sport tabs (10"x12") their M120 kit. with 3 people, half a tank and half throttle with the tabs down I'm on plane in 3 seconds I'm not sure if your buidling some sort of killer Pachanga but according to their website they are supposedly only rated for up to 60mph, I've never had trouble past 60 mph though
blckkat is offline
Old 09-07-2007 | 03:15 PM
Hmmm, I'm hoping to rebuild my engine this winter and get a little more out of it, hoping 70+. I was looking at 12x12 tabs so I think they should work for my set up
wet_rat is offline
Old 09-13-2007 | 01:34 PM
bcfountain's Avatar
Registered User
wetrat i have bennett racing tabs on my 22,i think they are 12+12 and have them mounted straight on the transom instead of the usual angled mount.i did this because of the lack of room on the transom and i can through bolt them instead of just screws into the transom.i have ex-hyd sterring,and the space was tight.the tabs work great,but i only use them in rough water at speed.no handling problems.rember the pachangas have a foam core transom.so through bolting is a must.hope this helps.
bcfountain is offline
Old 09-13-2007 | 05:36 PM
Just what I was hoping to hear--someones personal experience.
Thanks BC
wet_rat is offline
Old 09-14-2007 | 09:12 AM
Let me tell you from personal experience its going to take allot of HP to get you there. My third engine(496) finally got me to 75 on GPS If I did it again I would build a 540
1BIGJIM is offline
Old 09-14-2007 | 10:05 AM
bcfountain's Avatar
Registered User
Default big hp
i know what bigjim is talking about.i have a 525 in the p-22 and it is only running about 74-76gps.i was hoping for more .i have been told that if i put the same motor in my27fever it would be alot faster.i guess the diffrence in the hull design is alittle better.
Old 09-16-2007 | 04:38 AM
well, sounds like the old changa will be staying stock. I'm looking at a bigger boat for longer cruising so I think the changa will stay stock as a lake boat.
wet_rat is offline
26sonic
04-30-2008 03:08 PM
26sonic
Sonic
8
05-12-2006 09:23 PM
Python82
03-14-2006 06:08 PM
Monty
6
05-16-2005 01:24 PM
MnFastBoat
05-04-2005 08:34 AM
