Standard vs HP Gimbal
I hate the winter!!
What exactly is the difference between the 2? I know the gimbal ring and related hardware is different, but are the bellhousing, gimbal housing and transom plate the same? Would simply replacing my standard gimbal ring for either Mercs HP or Imcos ring be enough?
I am running an NA 540 with 725 hp and 680 torque. I beat it up pretty well, run the ocean as often as possible. I am getting worried that my standard gimbal will break, or the hinge pins will walk out. BTW, the boat is a '99 259 Convincor.
