watercooled turbo's >
watercooled turbo's
watercooled turbo's
Old 09-08-2007 | 09:22 AM
hoozeyurdaddy's Avatar
Default watercooled turbo's
is there anyone in this vast world of OSO that can tell me of a small watercooled turbo that has been used on diesel or gas engines, needs to be watercooled. any info welcome.
hoozeyurdaddy is offline
Old 09-08-2007 | 09:35 AM
BUIZILLA's Avatar
instigator
that's what I do for a living.... there are quite a few selections...
I am a Garrett, Schwitzer, KKK, Borg Warner, and IHI Master Distributor..
JH
BUIZILLA is offline
Old 09-08-2007 | 09:49 PM
Turbojack's Avatar
Gale Banks had a number of Turbo Packages for boats. You can see pictures of package in other thread going on now.
http://www.offshoreonly.com/forums/s...d.php?t=167130
You can see the water cool coller that goes around the outside of the turbocharger. I believe in later years they made a turbocharger with the water passage in the turbo but I never saw one in person.
Turbojack is offline
Old 09-08-2007 | 10:48 PM
most of the water cooled turbos went on generators
turbo2256b is offline
Old 09-08-2007 | 10:51 PM
Watercooled the 4 exuast houslng myself on my 30 ft small block twin turboed boat. I rolled 1/8 304 stainless steel plate in radius around exuast housing. Made end plates tig welded togther. Drilled and weled water in and out fittings. Has worked fine for 12 years. Boat was electmotive computer controled ingnition, lake water intercoolers. Motors made over 700 HP with 14 PSI of boost. O-ringed heads now running 18 PSI for 10 years with out a problem.
Turbos Rule Good luck
BDARCHER is offline
Old 09-09-2007 | 03:55 AM
The KKK turbo used on some VolvoPenta Diesel (TAMD40) is Ok for the big block Chevy,the exhaust housing is water cooled and the exhaust turbine is made in Inconel so it can support the exhaust temp made by fuel engine.
you just have to check the wastegate to get the right boost.
caldente is offline
Old 09-09-2007 | 08:25 AM
cougarman's Avatar
have any pictures of your set-up? Sounds nice.
Jon
cougarman is offline
Old 09-09-2007 | 09:00 AM
Will try to post some today. But not very good with computer.
BDARCHER is offline
Old 09-09-2007 | 09:29 AM
cougarman's Avatar
BDARCHER,
Are you part of Archer Marine ?
Jon
Old 09-09-2007 | 12:11 PM
Itīs a KKK-26
the Early Porsche 911 (930) Turbos used it too.
MikeyFIN is offline
