Super charger on 454 >
Old 09-11-2007 | 07:05 PM
blue thunder's Avatar
Default Super charger on 454
Would it be possible to run blowers off of 525SC mercs on Mark IV 454s? I have edelbrock alum heads but am concerned they might not mount up. If they don't is there a way to make them?
BT
blue thunder is offline
Old 09-11-2007 | 07:21 PM
Yes, I believe the deck height is the only issue, if even that. There are tall and short deck manifolds available or you can get spacers.
ghittner is offline
Old 09-11-2007 | 07:55 PM
If I'm not mistaken the 525SC's were 454's. Bolt on and go baby!
Darrell.
DMOORE is offline
Old 09-11-2007 | 08:05 PM
525SC blower packages have rectangular port intake manifolds. You may have to modify your heads where the intake ports meet or switch to an aftermaket manifold.
It will certainly work, but you may have to make some changes.
Griff is offline
Old 09-11-2007 | 08:15 PM
There are oval port intakes for the weiand blowers available new. And there is 1 available on ebay right now.
Old Navy is offline
Old 09-12-2007 | 12:59 AM
You can run a rectangular intake on an oval port head no problem, I have done it... Just use the rectangular gaskets.
ghittner is offline
Old 09-12-2007 | 08:57 AM
If you're asking if the bolt pattern between the manifold and head are the same, yes. So is the deck height.
As was pointed out, the 525SCs manifolds use rectangular port heads. Are yours oval or rectangle? If oval.
rdoactive is offline
Old 09-12-2007 | 10:13 AM
StraightJacket's Avatar
The Combustion chamber size on an Eldebrock head is less than a 990 casting hi-po head. This means your compression ratio will be higher than stock and you will risk the chance of blowing a head gasket or lifting the head. Do you have the performer, or the performer rpm series , The rpm 's are offered in a square port which has the 119 cc chambers, any of the ovals are a 110 cc chamber.
StraightJacket is offline
Old 09-12-2007 | 12:48 PM
Thanks for the replies, it sounds like I may be in a good spot. Heads are rpms, rect port with open chambers. When I built them I used cometic head gaskets and faria exhaust valves. Compression is about 9:5 now.
Any idea how much boost I could run and what sort of hp increase to expect. I run a cam with 112 lsa and about 564 lift, 230 duration or thereabouts.
BT
Old 09-12-2007 | 12:52 PM
Is that 9.5 CR????? Thats way high for a blower motor.
I would say 3-4# boost max.
Griff is offline
