Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Must see...best bottom paint remover!!! >
Old 09-13-2007 | 04:57 PM
Default Must see...best bottom paint remover!!!
I've tried them all, nothing compares. Captain Lee's. Spray on out of a plastic bottle for a couple minutes then wipe off. Check it out:
Attached Thumbnails Must see...best bottom paint remover!!!-corsa-005-large-.jpg   Must see...best bottom paint remover!!!-corsa-006-large-.jpg
jdub is offline
Old 09-13-2007 | 05:02 PM
Got it from Auto Ease out of VA. Google it.
jdub is offline
Old 09-13-2007 | 08:21 PM
Is it meth chloride based? Do you see meth chloride anywhere on the label? If so, be very careful, because it will soften gelcoat if it indeed has meth chloride in it.
I think the same company makes a soy based stuff that is supposed to be safe also.
Also, I think you got lucky. I do not see the epoxy barrier coat under the black stuff!
Fast Algae is offline
Old 09-13-2007 | 08:27 PM
No meth chloride. Safe on gel coat. And yes very lucky no primer. This stuff would take it off though. Even says on the label it will take off Imron.
jdub is offline
Old 09-15-2007 | 07:32 AM
Jdub have you finished stripping the bottom yet ? how did it work out any problems under the paint ??
mattd7 is offline
Old 09-15-2007 | 07:54 AM
Not yet, winter project
jdub is offline
Old 09-15-2007 | 08:30 AM
I spent all day yesterday, and will spend today - sanding off the barrier coat. I would halve like to try this stuff, but was told by more than one business that if I found anything that would soften the two-part epoxy barrier coat, it would also soften the gel-coat.
I am sick of sanding! Anything not you can not see on plane, will not get sanded! At least it is all smooth without the bottom paint....
Old 09-15-2007 | 10:11 AM
Buy a gallon and be done with it! I plan on painting the whole boat any way so I'm still going to have to sand the whole boat. This stuff will just make sanding the bottom alot easier.
jdub is offline
Old 09-15-2007 | 10:24 AM
I just sprayed some on the gel-coat and it will soften it. The spot I sprayed on the bottom paint the gel-coat is fine underneath. So I would say if you don't spray it driectly on the gel it's fine. It seems to take off a layer of paint at a time. If you do use it be careful.
jdub is offline
Old 10-17-2010 | 07:25 PM
Did the captain lees melt you gel coat? What did you end up using?
1bad96 is offline
HIGH LIFE
Magnum Marine
23
05-31-2008 08:50 AM
Buddy OO
1
02-14-2007 07:14 AM
Pantera24
13
10-17-2005 02:02 PM
Da Patriot
2
09-19-2002 07:34 AM
rockstrmkr
07-03-2002 11:49 PM
