moistuer metere
Old 09-19-2007 | 11:07 AM
Formula311-SR1's Avatar
Default moistuer metere
What is bad for moisture in the stringers? Looking at a boat with 2%, what does that mean and how much is too much?
Formula311-SR1 is offline
Old 09-19-2007 | 01:28 PM
glassdave's Avatar
Neno the mind boggler
2% is barely anything. 8 to 10 is average for boats that are regularly being used. at least thats what i am told.
08 OPA High Points Champion
glassdave is offline
Old 09-19-2007 | 02:22 PM
BraceYourself's Avatar
Unless it pegs the meter I think you are fine. 15-20 is normal on 10 year or older boats.
BraceYourself is offline
Old 09-19-2007 | 02:28 PM
Audiofn's Avatar
Charter Member #232
Did the meter get calibrated prior to use? They should have held a special metal plate under the meter to zero it out before they used it on the boat.
Jon
Put your best foot forward!
Audiofn is offline
Old 09-19-2007 | 03:07 PM
Thanks guys.
I'll find out about the calibration
Old 09-19-2007 | 07:38 PM
Default Formula
Stop by and grab mine you can try it out. Looks like it costs 20$ from Radio Shack , but they run about 375.00
Bill Kosick
Bottoms Up is offline
Old 09-19-2007 | 10:00 PM
jeff32's Avatar
mine was 800$ you can sometimes read 70% on newer baja that almost never slept in water... you can also get a 5% on a 1989 Bayliner 34 sportfish that stays in water year round. I'd say 50% is really acceptable in transom. of course less is better! you can even have 70% an it's not such a big deal on a short period of time... 70 after 3 or 5 years may turn to rot... I experienced big difference reading between some meters... as much as 60% !!! so make sure it is well calibrated, and on the fiberglass option for reading, not wood for example if you have different choices...
jeff32 is offline
jeff32's Avatar
maybe ed Cozzi here on the board could tell more about this...
jeff32 is offline
Old 09-21-2007 | 10:44 AM
Thanks all
Bill,
Thanks, as usual you are above and beyond helpful!!
Old 09-21-2007 | 09:52 PM
jeff32's Avatar
we are (I am) curious! what are your readings???
jeff32 is offline
