Hardin Marine Bravo Bellhousing & Oil Cooler Combination
Eliminate Stringer Mounted Oil Coolers with the Ultimate New Bravo Bellhousing & Oil Cooler Combo!
The all new extreme duty Bravo Bellhousing with its integrated Plate Style Oil Cooler solves the numerous problems that have plagued engine builders and boaters since the introduction of the bravo style engine packages.
Often a performance style engine oil cooler has to be mounted to far from the engines supply source. This results in long oil line runs which cause undue oil resistance and starvation of the engines internal oiling system.
By incorporating a superior plate style oil cooler within the engines flywheel cover these problems are eliminated. Now all of the engines oil system components can be attached directly to the engine, eliminating the need for stringer mounted oil coolers and sloppy extended length hoses.
The oil coolers chamber features large 1” NPT water inlets and is hardcoat anodized for maximum corrosion resistance. Each kit includes the appropriate high flow 8 or 13 plate cooler, adapter nuts and hardware. Oil plumbing sold separately.Call your Hardin Marine sales representative today for details.
