What type of engine oil are you running? >
Old 09-23-2007 | 08:52 PM
Default What type of engine oil are you running?
What type of oil is recommended in 500 or 525 EFI's
In my shop, I buy Shell Rotella 20W50 Engine oil. I run it in everything the company owns, pickups, dump trucks, excavators, all heavy equipment, and even small engines.
Would the Shell Rotella 20w50 be recommended in the 500 or 525 efi's?
If so, looks like I need to invest in a pump to change my own oil.
Mackattack is offline
Old 09-23-2007 | 10:34 PM
Hot Duck's Avatar
I used Mobil 1 synthetic (15w 50) in the 500EFIs in the last two boats without any problems and I am using Royal Purple (20w 50) in the Carolinas I have now. If you plan to keep this boat for a while, you might want to install a pre lube / oil change system from Keith Eickert. To change the oil you simpley attach a hose and flip a switch. It is that easy.
http://www.keitheickert.com/detail~ID~6842.aspx
Hot Duck is offline
Old 09-24-2007 | 10:39 AM
mwdill's Avatar
Amsoil 20w50
you can see and smell the difference
mwdill is offline
Old 09-24-2007 | 10:44 AM
Dean Ferry's Avatar
Veteran: Air Force
Lucas 20-50 racing Syn
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 09-24-2007 | 11:44 AM
pkspx's Avatar
I'm using 50w
EDIT* Just realized you were asking about the stock 500s or 525s, I would still be running 25-50w.
pkspx is offline
Old 09-24-2007 | 11:46 AM
jeff32's Avatar
used to use merc 25-40 but switched to penzoil 25-50
jeff32 is offline
Old 09-24-2007 | 11:48 AM
15w-40 Amsoil
h2oboy is offline
Old 09-24-2007 | 12:00 PM
Pennzoil 25W50
mrhorsepower1 is offline
Old 09-24-2007 | 08:48 PM
Swepco is as good as it gets if you can afford it.
Buddy OO is offline
Old 09-25-2007 | 07:24 AM
VelocityMark's Avatar
Mobil 1 15w 50
VelocityMark is offline
