Practical limits to closed cooling? >
Old 09-25-2007 | 08:17 AM
Default Practical limits to closed cooling?
Since I am having both motors redone (tired of unreliable POSs) I am thinking of going to closed cooling. Carbed BBC 502s will probably be 500-550hp 509ci when redone.
1) Can closed cooling handle the heat? (Florida salt water in the 80s)
2) Can I reuse my Gill exhausts?
3) Upgrading oil coolers as well to have thermostats and more cooling capacity - what size makes sense for this application (basically a big cruiser)?
Swamplizard is offline
Old 09-25-2007 | 08:52 AM
Thunderstruck's Avatar
I called Sea Kamp and got two kits for my 600 hp motors with aluminum heads. They work fine with no tstats. Only put closed cooling on the motors, leave the exhausts on raw water.
Tom
Thunderstruck is offline
Old 09-25-2007 | 09:42 AM
Registered User
588CI/880HP
http://www.go-fast.com/fwc_sc900.htm
Chris Sunkin is offline
Old 09-25-2007 | 11:05 AM
It say's the 653 cu in 1200hp is FWC, I like the idea of FWC.
excalibur32 is offline
Old 09-25-2007 | 11:24 AM
Registered User
Yeah, they had 3 of them in a 47 Apache a few years back.
Upside- no engine rot
Downside- you still have to flush the secondary side
-More junk to haul around- more weight
-More stuff to go wrong
-Expense
Old 09-25-2007 | 01:18 PM
2112's Avatar
I had two made out of American Industrial in Chicago. They make the Teague oil coolers.
They wanted to know how many BTU's I was trying to dissapate. I had no Idea and my Machinist/bottom end assembler was not able to give me the figure. In fact everyone I quizzed had no answer. I ended up going with huge units as they were bigger than any I was aware of. (5" diameter, 30" long) Top of the line double pass units.
They work well but I run in cold water. As Chris said, Expensive, more to rig, PITA but my engines love them.
2112 is offline
Old 09-25-2007 | 02:27 PM
I think my exchangers are 6"x30" 4 passes on the raw water side (inside the tubes). My motors run at 130-145 at any speed in 85-90 degree sewer water in LA and Texas.
Tom
Old 09-25-2007 | 03:18 PM
2112's Avatar
I am at 170-190. Water temp is 50. Maybe Ineed more passes?
2112 is offline
Old 09-25-2007 | 04:37 PM
blue thunder's Avatar
Mine are like Thunderstrucks but are 3 passes. They work great on 475 or so hp 454s. Other advantages are, no water pressure issues, no sediment in block, you can pressure test the cooling system the normal way, aluminum heads and intakes can be used.... the list is quite long. I'm a big proponent of cc. For the tiny expense and with virgin blocks I'd go for it.
blue thunder is offline
Old 09-25-2007 | 08:48 PM
Vinny P's Avatar
I hate the winter!!
I run Mercs closed cooling on my na 540 with 700+ h.p. Never a problem at all.
Vinny P is offline
