Crane 731 or 741 >
Crane 731 or 741
Crane 731 or 741
Old 09-25-2007 | 09:50 AM
Croozin2's Avatar
Default Crane 731 or 741
Who has used/is using either the 731 or 741 on a carbed 500hp? What other parts are you using with this combo? In the middle of my rebuilds and one cam already has a lobe wiped out so looking to make a change/upgrade. Or does anyone have any other cam that they are getting good numbers with?
Just checking what results others have had. Looks like the 741 would be a little much for an otherwise stock 500hp but.... Well, they do have headers rather than manifolds but other than that, basically stock.
Croozin2 is offline
Old 09-25-2007 | 10:08 AM
jryan26's Avatar
I used the 741 on some 540s. They had stock hp500 intakes/carbs and had awesome midrange. I plan on using them on some 500's I have now.
jryan26 is offline
Old 09-25-2007 | 10:09 AM
Beak Boater's Avatar
Charter Member # 545
We ran a 741, in a 540 with AFR aluminum heads and a whipple. Made good hp all the way through the rpm band. We put it in straight up. Have heard that advancing it a couple of degrees helps. Need more information on your parts. Are you running the Gil exhaust that came on it. Porting the heads any. Not a real gear head, Im sure that some of the engine builders on here will put you in the right direction.
Beak Boater is offline
Old 09-25-2007 | 10:19 AM
Croozin2's Avatar
BB, not doing anything other than a cam swap. Had a roller lifter fail in one engine wiping out a cam lobe. They only had around 180 hours on them. So, rather than take a chance on having a lifter fail in the other engine, pulled them both. These are basically stock 500hps other than the addition of some CMI E-tops. May put a little thinner head gasket to bump the compression just a bit but other than that, just changing cams and lifters and fresh rings/bearings/valve jobs.
I appreciate the input but I need real experience with the 502ci 500hp. I'm sure the bigger inch motors do liven up with the 741 and forced induction, though.
Croozin2 is offline
Old 09-25-2007 | 10:41 AM
Pat McPherson's Avatar
The 741 will extend the rpm range a little.
Patrick
Pat McPherson is offline
Old 09-25-2007 | 11:43 AM
The 731 is almost the same as the stock cam.
I would use a 525EFI cam. Its the same as a 741 except it has a 114 lobe sep.
Griff is online now
Old 09-25-2007 | 11:49 AM
Croozin2's Avatar
The standard 741 is on a 112* LSA?
Croozin2 is offline
Old 09-25-2007 | 11:58 AM
Yes.
http://store.summitracing.com/partde...1&autoview=sku
Griff is online now
Old 09-25-2007 | 12:42 PM
Thunderstruck's Avatar
Donald,
Call RMBuilder re cam advice. He is the expert.
However, most folks I've seen use the 741 are helping airflow with head porting/aluminum heads in addition to the cam.
Increase compression, port heads, better cam, ensure your stock carbs flow and you will get a noticeable difference in hp i.e. increased speed. Hunting and pecking with the performance parts can be dissapointing.
Thunderstruck is offline
Old 09-25-2007 | 12:44 PM
Also, RMBuilder can grind you custom cams for somewhat more than an off the shelf cam which may work better. He uses Kip at Cam Motion in Baton Rouge.
Tom
