alpha drives????
SS drives are completely different. Don't know how it's possible ALPHAs could be up graded to handle 500 hp. They might take it for a while if you baby them. They did upgrade gears and bearings when the bb was installed in front of it back in '87. That just helped them tolerate a stock 330.
Jim
Jim
I had a Formula 242LS with twin Alphas/SBC - no problems in 7 years. Three of those years were with 385hp engines. They seem to do much better handling higher hp/torque loads in twin applications where they can share the load. An Alpha has a little better hydrodynamic efficiency than a Bravo, but is limited to its own applications.
I think everyone will agree on one thing- they don't care much for going airborne, especially if you're not good and quick on the sticks.
Registered User
You don't want to holeshot or air out the prop with anything more than 300 HP. Big block torque will gobble hem up- even stock 330's. You also don't want to go from neutral into either engaged mode with the motor doing anything but idling.
