Towing cap. h1 hummer
Old 09-25-2007 | 08:50 PM
Default Towing cap. h1 hummer
Will it pull 10000 pounds?
Velocity Tom is offline
Old 09-25-2007 | 09:05 PM
'06 Alpha has 300 Hp / 520 ft. lbs. Towing capacity is 9,500.
Earlier years' towing capacity was about 7,500.
520 ft. lbs. is not a lot for a 10k load.
Don't know if I'd install a chip - don't know how strong the Allison 1000 tranny is...
cbeastwood is offline
Old 09-25-2007 | 09:57 PM
?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????:Whatever :
flat rate is offline
Old 09-25-2007 | 10:41 PM
PhantomChaos's Avatar
Originally Posted by flat rate
???????????????????: Whatever:
http://www.seriouswheels.com/cars/to...r-H1-Alpha.htm
PhantomChaos is offline
Old 09-26-2007 | 06:38 AM
Flat Rate,
What part of my post didn't you understand? If you have a problem with what I wrote, please let me know.
Old 09-26-2007 | 07:31 AM
haulinvols's Avatar
www.Bajaboatowners.com
Short answer is No. According to the Hummer site, the H1 Alpha is only rated at 9300 pounds in the soft top version and 9050 in the hard top version.
haulinvols is offline
Old 09-26-2007 | 08:36 AM
As long as you aren't going cross country and staying some-what local you might be OK. Remember, its not always in the HP and torque, its also the handling and stop side of it to factor in, if you do choose to tow it, keep a safe distance from others at hi-way speeds and check into some good fluid for that tranny, possibly even another larger tranny fluid cooler would help also.
Mercury_Challenger is offline
Old 09-26-2007 | 09:27 AM
haulinvols's Avatar
Here we go again, someone get the popcorn.
Jeffrey
04-02-2011 12:33 PM
Sick Stinger
Wanted
4
05-09-2008 03:02 PM
poolshrk
29
07-28-2007 01:25 PM
Bad Kittie
09-12-2004 08:22 AM
Bad Kittie
09-06-2004 04:16 PM
