Fogging a EFI >
Fogging a EFI
Fogging a EFI
Old 09-26-2007 | 07:59 PM
Craney's Avatar
Default Fogging a EFI
Whats the best way to fog a 500hp efi ?
Craney is offline
Old 09-26-2007 | 08:05 PM
I was told by someone not to fog efi's that it will clog the injectors. Any truth to this?
baywatch is offline
Old 09-26-2007 | 08:17 PM
The service manual says to use a remote outboard type tank, mix stabilizer and 2 cycle oil and idle for 5 minutes. I 've been told fogging may damage map sensor. I like to spray with storage seal in addition to gas mix. Never had a problem.
Jim
MOBILEMERCMAN is offline
Old 09-27-2007 | 03:06 AM
I've heard of using both marvel Mystery Oil and 2 cycle oil. What I've read about people doing is mixing a cocktail with the Marvel or 2 cycle in the water sep filter with fuel. Run the engine till it smokes, shut down and then change the water sep filters.
Personally, I never fogged an engine for a normal winter layup and never had any issues.
Griff is offline
Old 09-27-2007 | 08:50 AM
Elite Marine's Avatar
The concern is probably due to the new fuels that go to hell after 30 - 60 days and actually crystalize in the injectors.
Mystery Oil, Seafoam or 2 Cycle oil are good enough to prevent this from happening and clogging the injectors. Stabile can only do so much for the fuel so storing with as low of a fuel level as possible is best.
Elite Marine is offline
Old 09-27-2007 | 01:09 PM
monstaaa's Avatar
drain most of the fuel out from the fuel water seperator filer . refill with marvel mystery oil and reinstall. start engine and run until smokeappears. your done.
fogging or introducing oil into the dry plenum on efi engines, will usually ruin the mat sensor, or manifold air temp sensor. the oil ends up shorting the sensor internal as it is a wire element sensor.
also may ruin map, but usually that would take time if it happens and will not usually show up in spring.
you can also hydra lock the engine during its dormancy due to oil sttling and seaping thru dry intake into cylyders.
monstaaa is offline
Old 09-27-2007 | 01:36 PM
In addition to above procedures (whichever you prefer) how about removing spark plugs and putting a shot of oil in each hole then rolling it over a few seconds?
BadDog is offline
Old 09-27-2007 | 01:47 PM
Panther's Avatar
Frank's Marine Service
If you have the time!
Panther is offline
Old 09-27-2007 | 05:30 PM
upstate31sonic's Avatar
I have fogged two efi500s from the very first winter.This will be my 6th winter.Never had a sensor go bad..Am I just lucky or should I change the way I put my twins to bed for the winter???
upstate31sonic is offline
Old 09-27-2007 | 05:36 PM
Up state31sonic, I've been doing it a long time too. It's kind of like don't hot shot your boat it might hurt your ignition. Everyone one seems to have there own beliefs and preferences.
Jim
