transfering hubs
I have a prop I want to try. It doesn't have a hub in it. Its a worked prop just like mine, 26 b1. If I pop out my hub and swap it is there and thing I should inspect/check/replace before using it in the other prop. I didn't know if the rubber strips should be replaced or what.
Also if I want to get an extra hub, what type and where do you suggest I go
If the rubber strips have come off re-secure them to the sleeve or you can purchase just the sleeve under the Mercury or the Quicksilver label. (solid sleeve 1" prop shaft)
Part # 850821Q12
Part # 850821Q12
The rubber "snubber" strips can be cleaned and super glued back on.
There are 2 different length inserts. The Q11 and the Q12. (long story) Make sure you have the correct one for the correct propeller casting. If you struggle, let me know.
We sell new ones for $30.
[email protected]
[email protected]
