Newbie with TRS drives, Help! >
Old 09-29-2007 | 08:22 AM
Default Newbie with TRS drives, Help!
I just bought a 30' scarab with TRS drives on it. I understand these drives are not water cooled like the bravo's. My question is Do I need to do anything special to start the engines in my yard? I have already installed water inlets at the sea strainers so I can attach a garden hose to the engines. The engines are fresh water cooled. I am assuming as long as the transmissions stay in neutral I will be ok to run the engines right? I have some tuning to do to the engines before I drop it in the water so they are gonna need to run for a while.
Thanks In Advance
502ss is offline
Old 09-29-2007 | 08:59 AM
Biggus's Avatar
As long as you have water to the motors you're good to go.
The drives don't need water to run on the trailer.
Biggus is offline
Old 09-29-2007 | 04:25 PM
Thanks for the info, I got it plumbed and running today.
Another stupid question, How do you keep the garden hose from collapsing from the suction of the sea pumps when connected to the engines?
502ss is offline
Old 09-29-2007 | 05:16 PM
You're limited by the amount of water your can deliver. Usually that's about 5-7 GPM while your sea water pump needs about 30 GPM above 3000 RPM.
You'll need to limit your engine speed to 1500-2000 RPM.
Something you can do to help but not fix is to use a 3/4" hose...but they cost about $50.
gcarter is offline
Old 09-29-2007 | 08:26 PM
It collapses the line even at an idle. I guess I will try a 3/4" hose but I was thinking about just putting the pickup lines into a 55 gallon drum and letting them suck from there instead
502ss is offline
Old 10-02-2007 | 01:42 PM
Audiofn's Avatar
Charter Member #232
Don't use a cheap hose. Get the real good ones.
Jon
Put your best foot forward!
Audiofn is offline
Old 10-02-2007 | 03:44 PM
Wally's Avatar
Were doomed!
to keep the line from collapsing you need to open the shut off valve i assume you are closing off on the sea strainer from the thru-hull bottom pickup....this will let some air into the system.....the sea-water pump is creating a vacume....been there done that!
-Wally
Wally is offline
Old 10-03-2007 | 05:11 PM
I am shutting off the valves just befor the sea strainer. Should I be concerned with allowing air into the system, Won't it damage the sea pump impeller's?
502ss is offline
Old 10-04-2007 | 09:32 AM
Wally's Avatar
Were doomed!
As long as you have a decient water supply the pump can pass air with no problem...its when they run dry and heat up when the damage occurs. I work for a pump company...we tested the merc pump to see if we can adapt something along those lines in our product line....you would be VERY surprised at the amount of water the stock pumps can supply! And with a little lube (dish washing detergent in our case to get it started) they can pump a nice amount of air too!!!
-Wally
Wally is offline
Old 10-08-2007 | 02:46 PM
old bird's Avatar
Default first time here
Saw," Newby w/ TRS, Help," Thought, heck thats Me, read all and was enlightened, Thank You, I have a trans. leak, it seem to be back out at the transom, is there trans. fluid going to the trs drives.?
old bird is offline
