Fuel Tank Pick up
I've got a Donzi 22zx 454 MPI procharger. Thinking I should install a larger fuel p/up currently 5/16 hose as a feed. Does it need to an have an anti siphon installed or just a tube the bottom of the tank? How far of the bottom?? Any help would be great.
Bruce
Bruce
Make sure you also change the fuel filter head because the stock one with 1/4 pipe thread will not flow enough fuel. You could use 1" lines and not change the filter head and scatter the motor. A filter head with 1/2" ports would be the best.
Eddie
Eddie
I drilled my stock one out to 1/2". one inlet port for the tank feed, one for the fuel return and one out to the fuel pump. My tank had 2 3/8" pickups. I ran both of these into a 1/2" Y into the fuel filter head. No siphon balls/check valves.
