Battery Removal >
Battery Removal
Battery Removal
Old 10-02-2007 | 03:13 PM
Default Battery Removal
I want to pull my batteries for winter storage. Will I be able to use the factory jumper cables with a battery pack to lower the hatch after the batts are pulled? Or do the batteries need to be in place to "complete the circuit"...so to speak?
2006 Lightning BTW.
techman is offline
Old 10-02-2007 | 03:32 PM
Wally's Avatar
Were doomed!
well its gonna be easy to test out....open the hatch...un-hook the batteries and try out your jumpers to try and close the hatch! you'll find out right quick if it works!
-Wally
Wally is offline
Old 10-02-2007 | 03:41 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
My jumper cables go directly to 1 of the batterys. If anything, you could simple bolt the cable ends together from both the jumper leads and the main power cables.
US1 Fountain is offline
Old 10-02-2007 | 04:08 PM
Downtown42's Avatar
Originally Posted by techman
Will I be able to use the factory jumper cables with a battery pack to lower the hatch after the batts are pulled? 2006 Lightning BTW.
yes.
Downtown42 is offline
Old 10-02-2007 | 06:05 PM
Ginger or Mary Ann?
Originally Posted by Downtown42
yes.
So your jumper cables go to a switch instead of the battery then?
Old 10-03-2007 | 07:55 AM
You can use the jumper cables, but you need to "connect" the negative post wires (at the battery) together with a bolt/nut, otherwise ... nothing happens! Don't remember if you need to turn the switch on or not, but I do know you need to connect those wires together!
bob_t is offline
Old 10-06-2007 | 12:46 PM
fountain27ho496's Avatar
Uh, Take the bolt out of the ram and put a strap in. And It wont matter.
fountain27ho496 is offline
Old 10-06-2007 | 07:32 PM
Reggie's Avatar
Just leave them in the boat, and give them a charge or two over the winter.
Reggie is offline
Old 10-09-2007 | 02:58 PM
I won't be able to touch them during the winter layup if I leave them in. I guess no harm in giving them a full charge now and then see where we are in the spring. I wasn't sure how much I shorten their lifespan by leaving them in there during the winter freeze.
techman is offline
Old 10-10-2007 | 08:24 AM
BeakBoater35's Avatar
I tie the negative battery cables on the port side together with one of the battery box posts and then turn port battery switch to both. Works fine. (1997 35 Lightening)
BeakBoater35 is offline
