Looking for someone around Algonac MI to pull out pillings or cut them off underwater >
Old 10-03-2007 | 11:11 AM
phughes69's Avatar
Default Looking for someone around Algonac MI to pull out pillings or cut them off underwater
My dad expanded his boat house and now needs to have some pillings that are almost in the middle of his boat house removed. He is trying to find someone who has an underwater chainsaw that can do the job. He cant use a crane because the boathouse is covered by a deck. He could try to pull them out using a chain fall, but he would need a bean 14' long to span the boat well. He talked to a local guy that installs seawalls, but the guy did not have the equipment to remove it.
phughes69 is offline
Old 10-03-2007 | 01:38 PM
Strip Poker 388's Avatar
Rob
Local bar closed down, before and during picks. I watched some being pulled,they hook a cable and pulled them sideways from land, they claim most broke off at the mud line ,suposledy there were 10ft into the mud, when looking at the stack on poles on land there were a lot that were shorter that others. they say you cant really pull straight up because of the suction ,but if you wiggle back and forth it might come up.
Attached Thumbnails Looking for someone around Algonac MI to pull out pillings or cut them off underwater-hustler-dock-9-12-04-047.jpg   Looking for someone around Algonac MI to pull out pillings or cut them off underwater-dock-002-large-.jpg
Strip Poker 388 is offline
Old 10-03-2007 | 01:58 PM
Rob
lots of poles
Attached Thumbnails Looking for someone around Algonac MI to pull out pillings or cut them off underwater-dock-poles.jpg   Looking for someone around Algonac MI to pull out pillings or cut them off underwater-dock-3.jpg
Old 10-03-2007 | 08:47 PM
call one of the dive companys in michigan, they can do it, prolly going to be pricey though,
matt81 is offline
Old 10-03-2007 | 09:44 PM
If you find someone with a large jetting device, the pillings should come out easily. It's just like putting them in, only in reverse.
Baja_Bigdog is offline
Old 10-03-2007 | 10:05 PM
rush's Avatar
They may be taller than the roofline, if its knot that many I would get the chainsaw and know they were cut at the bottom.
rush is offline
Old 10-03-2007 | 10:41 PM
MES
Is that the place at the resevoir that Dewitt use to own?
MES is offline
Old 10-03-2007 | 11:54 PM
Rob
yeap, the law got so bad on DUI's, it put them out then he sold the marina.He at one time he was the largest bar in MS.
you been there before?
Old 10-04-2007 | 12:11 AM
"They may be taller than the roofline, if its knot that many I would get the chainsaw and know they were cut at the bottom."
hydraclic chain saw will cut them off on bottom, ive used them before underwater
matt81 is offline
Mbam
07-10-2008 08:37 PM
sotapop20
05-30-2008 11:25 PM
CAP071
08-06-2006 11:58 AM
