500efi Heads >
500efi Heads
500efi Heads
Old 10-04-2007 | 03:10 PM
Default 500efi Heads
OK - I KNOW THIS HAD TO BE DISCUSSED BEFORE, BUT...
I HAVE YEAR 2000 500EFI's approaching 250hrs.
This winter I plan on doing the recommended head gaskets, valve springs, etc...
My question is:
- Instead of having my stock heads reworked, valve springs, valve guides, etc... Are there aftermarket heads that are ready to bolt on and be able to see any signifigant gains in horespower without having to burn higher octane or do anything else serious to the engines. If so, what recommendations would you make. Thanks in advance. Ted
Donzi38ZXXX is offline
Old 10-04-2007 | 03:40 PM
You would have to do an ECM reprogram if do hp mods. Best bet would be to call a reputable builder with a proven package/combo that already has a dialed in package and has a dyno proven ecm recalibration already done.
Griff is offline
Old 10-04-2007 | 04:09 PM
Totally agree...There are plenty of great head packages out there, but they need to synch with your package after they get bolted on. Carder
Carder is offline
Old 10-04-2007 | 04:19 PM
Great! - Where would this person be???
Old 10-04-2007 | 04:20 PM
Great! - Where would I find these head packages?
Old 10-04-2007 | 07:34 PM
I used Tyler Crockett. You can email him @ his website;;;
crockettmarineengines.com or call him (810) 324.2720
He is helpful, and doesn't treat non-gear heads, (like me) like they are idiots. Carder
Carder is offline
Old 10-04-2007 | 07:54 PM
H2Xmark's Avatar
tyler crockett or mark at precision
H2Xmark is offline
Old 10-05-2007 | 06:19 AM
Canada Jeff's Avatar
Are you changing lifters? I ask because when I did my spring, we found a bad lifter. Changed them all. 240 hours.
Canada Jeff is offline
Old 10-05-2007 | 06:46 AM
Pat McPherson's Avatar
I was just debating this with a friend the other night.
It comes down to $$ as usual. Sure you can buy a better set of better flowing aluminum heads.
But, unless you change the cam along with them, are you going to gain enough to make the $$ worth it?
He has decided to have his GM heads rebuilt/valve job with new exhaust valves, springs,... and some bowl porting.
Patrick
Pat McPherson is offline
Old 10-05-2007 | 09:35 AM
Thats why I started this thread. Doing my research now so I have my ducks in a row for the winter projects. For me, dependability is important. I typically put around 50hrs a year on my boat - so whatever I do I am going to expect it to last another 5 years. Just like everyone else - if I spend thousands of dollars on preventive maintenance - it would be nice to get a little more punch in the process.
Also, I will not be replacing the cam unless I find its in trouble when I open it up.
CANADA JEFF
I will probably replace the lifters as well.
