When to rebuild 525SC motor ??????? >
Old 10-06-2007 | 10:30 PM
G Man's Avatar
Default When to rebuild 525SC motor ???????
Bottom end has 500 hours. Oid changed (MOb ! Syn) every 30 hours. When shouold it be rebuilt? Most time spent mid range.
G Man is offline
Old 10-07-2007 | 01:43 AM
Just buy it!!!!!!!!!!!!!
You should clarify that the top end was rebuilt at 350hrs. I would expect it to be fine for at least another couple hundred or more hours. Probably check the valve spring pressures in another 100hrs.
Griff is offline
Old 10-07-2007 | 08:25 AM
I would perform a compression and leak down test. This will tell you how bad of shape the ring seal is.
mrhorsepower1 is offline
Old 10-07-2007 | 07:40 PM
G Man's Avatar
Good one Griff !!! : ) d
G Man is offline
Old 10-07-2007 | 09:17 PM
What a waste of Mob1. You are draining good oil out at 30 hours. Especially if you avoid extended WOT.
GCAT911 is offline
Old 10-08-2007 | 02:28 AM
Maybe, but better safe than sorry. It's less than $50 for the oil and filter and cheap insurance. Also it makes sense with a average season of 60hrs on the engine. Change it for the winter layup and once half way through the season.
Griff is offline
Old 10-08-2007 | 09:29 PM
G Man's Avatar
I agree Griff! Good job!!
G Man is offline
G Man
5
10-05-2007 07:48 PM
ssilverado60
4
08-08-2006 12:35 AM
phastang
1
07-07-2004 09:27 PM
Von Bongo
17
06-22-2004 12:02 PM
forgetg
Fountain
0
05-15-2004 08:11 AM
